Step by Step Guide to Enabling Blind Spot Information System (BLIS) and Cross Traffic Alert (CTA)
Discussion in 'DIY' started by Bull Run, Jul 31, 2018.
  1. OP
    Bull Run
    Bull Run Well-Known Member
    Vehicle(s):
    2015 Mustang EB Prem PP
    Feb 24, 2017
    AZ
    642
    347
    Rating:
    100%
    2   0   0
    What's the part number for the brackets and how much did they cost? My sensors came with brackets but not the clips. I couldn't find the part number for the clips, so I just used bolts and double-sided tapes.
  2. db252
    db252 Equinsu Ocha
    Vehicle(s):
    16 GT Premium/PP/Nav
    Jan 1, 2016
    Northern CA
    1,006
    561
    Rating:
    100%
    4   0   0
    I got the part number for the brackets from your very first post. I ordered everything brand new from Autonation except the sensors which were salvaged. When all the parts showed up, the brackets had the clips on them.
  3. OP
    Bull Run
    Vehicle(s):
    Feb 24, 2017
    AZ
    642
    347
    Rating:
    100%
    2   0   0
    D'oh! Thanks, now I remember finding the part number for the brackets and didn't know they even came with the clips.
  4. nm_mustang
    nm_mustang Active Member
    Vehicle(s):
    2015 mustang V6
    Oct 17, 2015
    New Mexico
    I'm currently gathering the parts necessary to add blind spot to my base 2015 v6 mustang. I have a question regarding the BLIS mirror part numbers. When I enter FR3Z-17K707-D into Tasca parts the illustration shows BLIS, but the description states no BLIS. For FR3Z-17K707-G, the description does not state anything, and the illustration does not show a BLIS. Tried checking other part stores, but they all show the same thing. Just a little worried before I place the order.
  5. db252
    db252 Equinsu Ocha
    Vehicle(s):
    Jan 1, 2016
    Northern CA
    1,006
    561
    Rating:
    100%
    4   0   0
    It looks like you would want same part number but Q and R at the end instead of the other letters. Check to be sure.
  6. 300mag
    300mag Well-Known Member
    First Name:
    Vehicle(s):
    17 Ecoboost Prem Vert
    Sep 30, 2018
    Atlanta
    122
    someone asked in earlier post but didn't understand completely so my apologies for asking again, when looking for the sod modules do we just need to match the "14c689" up, or do we need to match the "em2z" prefix or "A" version at the end of the part#. Thx
  7. db252
    db252 Equinsu Ocha
    Vehicle(s):
    Jan 1, 2016
    Northern CA
    1,006
    561
    Rating:
    100%
    4   0   0
    Don’t fret about the number as much as the source to get them. Midway mustang on eBay always has quite a few. They are the source I used and were in perfect physical and working condition plus they state they come right out of a mustang.
    Eventually this link will sell but there are always more. The link is just an example but find ones that have no broken tabs. Email them directly for the best info.
    https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/162699354550
  8. 300mag
    First Name:
    Vehicle(s):
    Sep 30, 2018
    Atlanta
    122
    are the tabs required or do the brackets hold them in. did the ones you get from midway have broken tabs, just wondering if they could have been damaged from collision.
  9. db252
    db252 Equinsu Ocha
    Vehicle(s):
    Jan 1, 2016
    Northern CA
    1,006
    561
    Rating:
    100%
    4   0   0
    Mine did not have broken tabs and I was actually surprised to see that in their listing. The tabs are important as they take the small torx screws that thread into the mounting bracket.
  10. 300mag
    First Name:
    Vehicle(s):
    Sep 30, 2018
    Atlanta
    122
    Thanks I found a couple of others without broken tabs. just needed to adjust my search.
  11. 300mag
    First Name:
    Vehicle(s):
    Sep 30, 2018
    Atlanta
    122
    I should have all my parts tomorrow with exception of led's which will be here next week(backordered) hoping to run wires tomorrow and mount modules. does any know how the cavities are numbered on the black body control module connectr(or is the connector numbered) . Alot of the colors look similar so I would like just verify it is the correct wire based on cavity #of connector.
    located the ground and blue/white vpwr wire coming from camera.
    Thanks again for everyone's help, BSM/CTA is one of the options on my other car has and always wished my mustang had it. . so needless to say I can't wait
  12. db252
    db252 Equinsu Ocha
    Vehicle(s):
    Jan 1, 2016
    Northern CA
    1,006
    561
    Rating:
    100%
    4   0   0
    Those are it. Just confirm that their pin points are at 11 and 23 and you know you’re good. Either violet or gray to connect to is good as they are doubled up. Take your time.....they are a very small gauge wire.
  13. 300mag
    First Name:
    Vehicle(s):
    Sep 30, 2018
    Atlanta
    122
    special thanks to @Bull Run and @db252 for the write up and helping me out.
    I got the BLIS/CTA installed today and everything is working great. only issue I ran into is I thought the Connectors that rock auto sent were incorrect because they weren't going in all the way. I thought they may be incorrect since rock auto said they were superceded to part# wpt-1545. In the end it turned out the ebay modules I purchased had the rubber gasket and white cap from the connector stuck in them.
    Now I just need to install led's into a-pillar and put the trunk back together. How are you guys installing the LED's?? ? I was just going to drill a hole, insert from the back and hold in place with some epoxy or silicone.
  14. db252
    db252 Equinsu Ocha
    Vehicle(s):
    Jan 1, 2016
    Northern CA
    1,006
    561
    Rating:
    100%
    4   0   0
    Good job. I ended up using 5mm led holders from amazon that keep the led and the holder in place.
    Here you can see the area I smoothed out and then drilled for the holder to fit. The led snaps in and stays in place.
  15. db252
    db252 Equinsu Ocha
    Vehicle(s):
    Jan 1, 2016
    Northern CA
    1,006
    561
    Rating:
    100%
    4   0   0
    It’s the little things but for the first time a couple days ago my headlights activated while one of the blis lights was on and I noticed it dimmed with the headlights turning on obviously to make the light less intense at night. Just something I observed.
  16. OP
    Bull Run
    Vehicle(s):
    Feb 24, 2017
    AZ
    642
    347
    Rating:
    100%
    2   0   0
    I got the led holders like db252 did but I found that the light fit the hole tightly so just pushed it in and hasn't worked itself out yet.
  17. 300mag
    First Name:
    Vehicle(s):
    Sep 30, 2018
    Atlanta
    122
    Thx, I ended up just drilling a hole and epoxing from behind and its barely noticeable until it lights up. wanted to get everything put back together and didn't want to wait for holders from Amazon. I was contemplating going with the oem mirror glass until I saw what a PITA it is to run a wires into the door, saved myself $200
Loading...
Share This Page
