Steeda's S550 Rear Lower Control Arm Spherical Bearings - Now Available!
David@Steeda
David@Steeda
United States
www.steeda.com
David
Bolt-on, slammed S197
David@Steeda
David@Steeda
United States
www.steeda.com
David
Legionofone
2016 Mustang GT Base
Someone needs to figure out an easier way to get these in without taking the entire rear of the car apart, Remember, if you take off the axle nut you are supposed to replace it. If we could press it off on the car by just dropping the inner LCR mount and could use something like a pully puller to push it in with a socket that would make life 100x better.
dimitarm
Macedonia
Mustang GT 2015 V8 EU
are these the same as ford racing Knuckle Toe Link Assembly?
Myshelby3425
Miami
2018 GT
Is there an easier way to installing this without taking the full rear apart? Can lower control arm be unbolted and pulled down to press out the bearing and install the new one?
leszek
Kirkland, WA
S550 CO GT PP vert
In theory yes, in practice YMMV. For example in my case one of the bushings pressed out OK with the portable tool. The other destroyed that said tool and a small press as well. A 50 ton press had to be used and so there was no way to do that on the car itself.
Myshelby3425
Miami
2018 GT
Damn.. So if all goes smoothly, it is possible just to unbolt and pry it down a bit to have it pressed out? BMR sells a tool also to press out the bushing to avoid taking to a machine shop.
leszek
Kirkland, WA
S550 CO GT PP vert
Why do you worry so much about taking off the lower control arm? You do that anyway when you replace the rear springs for example and a lot of people did that themselves.
Myshelby3425
Miami
2018 GT
More work and more crap to take off.
