Steeda's S550 Drag Rear Sway Bar - Now Available!
David@Steeda
United States
www.steeda.com
David
Bolt-on, slammed S197
Our track-proven Steeda Drag Race Rear Sway Bar for your 2015-2016 Mustang GT, EcoBoost, or V6 will provide substantially reduced body roll to support high horsepower applications through any drag race requirements! Our drag race rear sway bar will make sure to keep your car pointed straight down the track, no matter how much power you're making. This is the same drag rear sway bar that John Urist runs on the fastest production-based factory IRS S550 Mustang in the world!
Steeda Mustang Drag Race Rear Sway Bar (15-16 All) | 555-1018
Key Benefits:
- Installed on the fastest factory IRS S550 in the world!
- Drag Rear Sway Bar diameter 1-1/8" - Solid
- Improved stability during launch
- Reduced body roll
- Machined steel billet sway bar ends, less prone to cracking/fatigue
- Competition-proven
- Includes sway bar bushings
- Designed and manufactured in-house in the USA by Steeda
- Lifetime warranty
Our welded billet ends on our drag rear sway bar are far stronger than stamping the end of the bar. Billet-machining construction of the sway bar ends makes for far greater strength for a bulletproof sway bar, that can take a beating no matter how much power your S550 is putting down.
Our line of Steeda sway bars are equipped with machined steel billet sway bar ends, whereas others on the market have coined ends. What does this mean? Our sway bar ends are machined out of billet steel round stock, in-house, on our multi-axis CNC lathes and go through hundreds of computer simulations to ensure the ultimate in strength and performance - this provides greater resistance to bending stresses, and has three major advantages:
1 - These parts are less prone to cracking/fatigue failure on the ends themselves.
2 - Billet sway bar ends reduce unwanted deflection - excess deflection creates unwanted geometry changes, which physically changes your sway bar stiffness to a non-ideal rate.
3 - With less unwanted deflection, our bars will 'wear out’ slower - any spring will eventually become softer over time as it is cycled through its life, our bars will maintain their designed rate for longer with less unwanted deflection.
Our bar rates are developed and optimized through advanced vehicle dynamic simulation and through extensive real-world testing. We engineered our Steeda Mustang Drag Race Rear Sway Bar to reduce body roll and improve stability during hard launches. The added stability that this solid drag rear sway bar offers will keep your S550 Mustang pointed straight!
In stock and ready to ship!
