Steeda's S550 Billet Rear Shock Mounts Are Finally Here!
RoadCone
Ohio
2016 Competition Orange PP
Agreed. I am a Steeda fan, but there is no excuse to have the most likely problem 1) not covered by the instructions and 2) not providing the special tool to mitigate it.
I still think they could source the open side socket or offset wrench in bulk for cheap. Or redesign the top of the mount and nut to work with a regular box end wrench.
I will be putting these on with Viking Warriors, what size is the socket I will need to get in preparation?
GTP
Deutsche Pony
Indy
www.BambergAudio.com
Philip
The top nut is 21mm (13/16 also fits).
In lieu of purchasing a $15 open side socket, you are better served by using vice grips on the shaft just under the mount. (The shaft is much harder than the VG.)
Do not skip blue threadlock with any method.
FlyBy
NorCal
2015 Mustang GT Wimbledon White
Many thanks to the Steeda guys (Mike, Matt and Jaime) for their excellent customer service. The mount with the loose bearing needs to be replaced, it's too loose if you can move it around with your finger. If you mistakenly get one of those, don't install it, just call Steeda and they'll fix you up. Replacements are on the way, shipped out the same day I called.
tampasnake
Tampa, Florida
Shelby GT350R
I'm going to talk to Steeda tomorrow. After taking mine apart yesterday all the noise I am hearing is from the bearings. Each time there is movement with the bearing I get the noise. It's almost like they bind and then release all at once. I was able to reproduce the noise with them off. Also just jacking it up and letting it down you can hear the bearing moving.
This explains why I only get the noises at slow speeds on uneven surfaces. On the highway I go over bumps on flat surfaces there is no noise.
Evo_Rob
Mmm... Boost...
Virginia Beach
Rob
Any update? I talked to Jani on 8/28 and called John on 8/29 and was told I'd be contacted about it. Just don't want to bug you guys every week lol
Bump??
tj@steeda
Timothy
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
Just ordered the 12mm mounts from LMR...we will see how they work when combined with Koni's and BMR's SP080 springs
They are a very nice and noticeable improvement if you have gone stiffer on suspension rates or locked down the IRS.
tj@steeda
Timothy
We look forward to your review & in the future, if you ever need ordering support, don't hesitate to ask!
Best Regards,
TJ
tampasnake
Tampa, Florida
Shelby GT350R
Thank you TJ and Steeda for standing behind these. I got the new ones on over the weekend and it's a night and day difference. It was very noticeable even during the install the first set of mounts the bushings in the mount very difficult to move and when I got them too there was a loud release from the bearing unbinding. The new ones movement is fluid.
SteedaTech
Pompano Beach, FL
2016 Mustang Q750
Updated application chart
tj@steeda
Timothy
Great review from a customer ... wanted to share:
Ryan S.
Review: Over the course of my s550 build I've hit a bunch of modding walls due to having a lowered ride height. Each time I was able to find a steeda product that solved my issues and improved the handling and feel of the car. Recently I purchased RTR ADJ shocks/struts at a low introductory price of approx $400. Unfortunately when I attempted 1st install, the rear shocks were missing strut top nuts and the new shaft diameter was larger than stock(12mm like Koni Yellows) and required drilling. I informed the other vendor of this but they were no help.
I ended up going to the hardware store to determine the thread size and immediately looked to Steeda for a bolt on solution and these mounts fit the bill. Install was a breeze and was easily done in an hour with hand tools and a floor jack. The Steeda rear mounts have a nice solid feel to them despite being surprisingly light. After driving on them for the past few days these mounts w/ the upgraded shocks, its clear that the rear end float and bouncy feeling I used to get with the stock PP shocks is gone. Just for a bit of perspective, I also have the Steeda Ultimate stop the hop package, adj bump stops, adj rear camber arms, installed a year prior to this upgrade.
jperls
Thousand Oaks
Jason
2015 Magnetic Metallic V6, 1970 mustang convertible
Best Regards,
TJ
Installed them today...only 1 hour from jack stand setup to back on the ground. The difference in night and day. The combination of these billet mounts with the Konis and BMR's SP080 springs is absolutely incredible.
[MENTION=7748]tj@steeda[/MENTION] and [MENTION=9985]BMR Tech[/MENTION], you guys should get together and do a combined build. Personally, I think the setup should be as follows if this does go through:
1. JRZ Pro RS Coil-overs
2. BMR Front Sway Bar
3. Steeda Rear Sway Bar
4. BMR Spherical Vertical Links
5. Steeda Billet Shock Mounts
6. BMR Sway bar end links
7. Steeda Rear Adjustable Camber Arms
8. BMR Chassis Brace (4-point)
9. Steeda adjustable toe links
I think you all get the idea... :)
tj@steeda
Timothy
You think that is good ... you should have went with the entire Steeda package :eyebulge:- we appreciate the feedback & support!
TJ
