They should fit the same as they are manufactured to the same specs.Am I missing something or does the delrin one fit differently than the billet one?
I'm just going by the two pictures posted, the billet one looks like a standard pull up collar, but the delrin one looks to be a push down, after looking on the website it says the delrin one is a pull up, but I am not seeing how?They should fit the same as they are manufactured to the same specs.
Best Regards,
TJ
Hi Tom,My aluminum collar will no longer stay attached to the plastic lockout under the boot of on the OEM shifter. I'm guessing the 3 clips have either broken off, or were sheared off by the collar. Does anyone know the part number for the lockout collar under the boot?
Fortunately I can still use reverse by grabbing the lockout through the boot and pulling up.
I don't think it is the fault of the Steeda collar, but I do not know for sure since the lockout is working again and I have not had to pry up the boot and trim to take a look. If it comes loose again I will dig into it and call Jamie. Thanks.Hi Tom,
Please reach out Jamie at our Valdosta plant and he will help you get squared away. 954-960-0774
Thanks,
Mike D
