Steeda's Extreme Ultralite Linear Lowering Springs - Thoughts?
tj@steeda
Timothy
Can you pm me with a quote for the fronts only. I want to know how much to see when can I pull the trigger. Shipping to 34772.
Replied!
Best Regards,
TJ
SteedaTech
Pompano Beach, FL
2016 Mustang Q750
Any discount code? gonna grab them next Friday
Also will I need camber bolts for these?
I will have Tim pm you.
I would recommend camber bolts for sure.
Supa LA
Drop a gear and disappear
So. Indiana
2015 Guard Metallic Mustang GT PP
I grabbed a set of camber bolts for my install. They tech at Tire Discounters was able to get right at -2* of camber. Solid.
tj@steeda
Timothy
SUPABAD
I95
`16 Shadow Black GT PP
Standard PP tire size and wheel size.
With 1" Spacers? Absolutely perfect :headbang:
Those will be my Spring/Summer wheels...
:) Fronts are 275/35/20 and rears are 315/35/20.
It looks like you got 20x9's on the EcoBoost... Is that correct?
I just picked up a set of 20x10 Icons with a +40 offset not too long ago and I'm looking to do 275/35/20 squared for the Fall/Winter.
Will that setup clear the well (20x10)? If not, what size tires would you recommend on that size wheel with these Ultralite Extremes or would they be too wide?
SteedaTech
Pompano Beach, FL
2016 Mustang Q750
20x9.5 +45 offset are on the EcoBoost with that spec 275/35/20 would be fine
tj@steeda
Timothy
We need more pics of aggressive fitments with these springs... C'mon guys, don't be shy and show us your setups! :ninja:
:D
Yes, let's see em!
I have seen a lot on Facebook ... hopefully they are members on here too
TJ
dev1360
STL
DIB 2016 S550
Just ordered a set Friday. Will be installed with 25mm front spacers and 20mm rear spacers on my PP. (25mm rear pokes the tires just a tad, and I hate poke, so I will trim the studs and run 20mm rear. Should be perfect.)
Once it is all installed and aligned with camber bolts I'll post pics.
tj@steeda
Timothy
Sounds like a plan :thumbsup:
TJ
tj@steeda
Timothy
Another shot of a customer's car from Facebook - posting on his behalf!
tj@steeda
Timothy
Supa LA
So. Indiana
Thanks Tim! Lol, i couldnt get these uploaded for the life of me. :frusty:
dev1360
STL
DIB 2016 S550
Ultralight Extreme Linears and 25mm front spacers with 20mm rear spacers. Also next to a stock PP for good measure.
