Steeda's 3-D Printed CAI Prototype - 2015 to 2019 Mustangs (Video Inside!)
Houston Kid
Houston, TX
The dyno sheet shows 20 hp added, I assume that’s with a tune correct?
It requires a tune according to the site so it has to be with a tune.
cobra199711
N.FL
19 A10 GT
Yeah, I figured these numbers were tuned.So, it’s probably worth 10-12 hp.
‘ 25 over stock
30HP increase over stock at mid-range [max gains]
• Fits all 2015+ S550 Mustang GTs, including 2018 and newe
Houston Kid
Houston, TX
• 25HP increase more then stock
• 30HP increase over stock at mid-range [max gains]
• Fits all 2015+ S550 Mustang GTs, including 2018 and newer
• Includes our washable Steeda S550 Mustang Oiled Air Filter ( #555-3221)
• Quick and easy install
• Used on the Steeda 'Silver Bullet', the FIRST NA 2018 Mustang to get into the 10s in the ¼ mile (Click here to see it in action)
• ***TUNE REQUIRED***
‘ 25 over stock
cobra199711
N.FL
19 A10 GT
So, is it any different than most tune needed CAI? They all seem to generate close to the same power WITH a tune added. It looks good though!!
SteedaTech
Pompano Beach, FL
2016 Mustang Q750
Until your at cruising speed and above, it will knock the others out of the park!!
Enjoy this new video! Steeda Tech
LETHAL
From the D but in the NC
Asheville, NC
Kevin
2018 GT A10
This is just a LID AND TUBE? no box?!?
LETHAL
Asheville, NC
Kevin
2018 GT A10
Got mine in this morning from Fed Ex.
So lund has given me the revision for the Steeda sealed box..Does that mean with or without the insert?
Can the insert be used for street use? The instructions say "performance and racing " use without the insert.
Myshelby3425
Miami
2018 GT
What’s the insert?
LETHAL
Asheville, NC
Kevin
2018 GT A10
Plastic reducer that goes into the lid to limit the diameter around the MAF.
tj@steeda
tj@steeda
Timothy
This ...
tj@steeda
tj@steeda
Timothy
No, you essentially need two (2) tunes to written for both restrictor and non restrictor.
The restrictor offers better drivability on the street whereas the non restrictor application is better for the track.
TJ
