Steeda Vertical Links Install: FAIL.
Robby
Munich, Germany
'16 DIB 2.3T
Easy job right? Only 2 bolts. Right? Well they just wouldn't line up. Either I would get the top one in and the bottom wouldn't or I would get the bottom one in and the top not. Despite jacking in various places, body, under the knuckle, rubber mallet, pry bar etc.----Just a total NOGO! And mine didn't come with any grease.
After 3 Hours I gave up and decided to put the OEM part back on. Bolted right in and torqued to spec. Took all of 2 minutes. Wasted afternoon. Very disappointed. Was going to install the sub-frame brace, but had no more time nor patience for Steeda today.
tj@steeda
Timothy
Let me check into this for you with our install team - see what may be taking place in order to help you install.
I will let you know as soon as I hear.
Best Regards,
TJ
Gnfanatic
Long Island
2017 Ruby Red GT PP, 1986 Buick GN
Its the installer, not the part. Took my 35 min to install mine and used a jack to jack up lca a tad.
PrimetimeKenny_S550
Kenny
2016 Mustang Gt- Mt82
You have to twist the rear knuckle, I used a 2 foot crowbar for leverage. Get the tool bolt in first. It can be a pita, but it will fit.
jdoug
Regular Guy
SoFla
Doug
2019 Mustang GT A10
Had some trouble with mine too but finally got them lined up. Had it on a lift too, but still had problems. Can't imagine doing it in my driveway.
wildcatgoal
@sirboom_photography
TBD
Steeda's vertical links have a very tight tolerance and aren't as easy as the Boomba poly or spherical options to install. Watch the CJ Pony Parts install video for how to line things up. I struggled myself, but got it done. I feel ya, but these are the right vertical links for the job. I have had Boomba and BMR spherical before... these were right in my mix.
Robby
Robby
Munich, Germany
'16 DIB 2.3T
I was using a jack and jack stands. My crow bar was just too long to get any kind of leverage.
LETHAL
From the D but in the NC
Asheville, NC
Kevin
2018 GT A10
Took me longer to pull the wheel off than to install the verts on each side. Rubber hammer and a screw driver to line up the holes for future reference.:cheers:
tj@steeda
Timothy
Might be time to change the headline - I get nervous every time I see it lol.
