Hello All:
If you are on the fence ... I just wanted to pass along this review!
Best Regards,
TJ
http://www.steeda.com/2015-swaybars/Despite TNcoupe's good advice, I had the dealer install the sways at the minimum setting, figuring that I can easily change it to stiffer if and when desired.
I am stunned by the improvement over the springs alone while driving the canyons at speed. Yet another major dollop of confidence with far more stable turn entry, execution, and power out without nervousness or float induced by road imperfections mid-turn. The ride is a bit firmer for sure, but bumps end sooner with almost no rebound-y ringing anymore - hit bump, then the bump is over immediately without drama. No bobbing.
Do it folks. This is the set up the perf pack should have been. Now the chassis is a much better match to the marvelous powertrain.
Great job, Steeda (and Ford); wonderful combo.
Also did the post-break-in change to Mobil One Extended Performance Full Synthetic 5W20 that I bought at Walmart. The dealer did it for $20 including the oil filter!
Best Regards,
TJ
