SR56
- Mar 16, 2016
- Orlando, FL
- Website
- seanrooney.realtor
- Sean
- 2016 GT PP
Been looking through the forum and there is information in bits and pieces all over, but not a collective gathering that I've found. Looking to see what others are running with as well as comments or suggestions for how you dialed in. Hoping to make this somewhat of a resource guide.
List your Steeda suspension mods, then adjustments for their Pro-Action dampers and sways, or other tweaks you may have done.
I'm also listing my ride height measurements.
Car: 2016 GTPP
Notes: Suspension installed by Steeda Pompano in June 2016. Sway settings are the same as install. Dampers were set at full soft during install and adjusted by me. Goal is to do road courses on occasion.
My Steeda Mods:
Stop the Hop Kit
Linear Sport Springs (1" Drop, 200 F / 800 R lb/in rated)
Pro-Action Shocks & Struts
Front 1 3/8" Sway
Rear 1 1/8" Sway
G-Trac Brace
Stock PP PZero rims/tires in OE sizing
Measurements / Adjustments
Front Struts: 1.5 turns from soft
Rear Struts: 1.5 turns from soft
Front Sway: 2nd hole from soft
Rear Sway: Middle hole
Linear Sport Springs Height Measurements
Front middle splitter: 6 1/4"
Front right/left quarter in front of tire: 6 1/4"
Front right/left quarter tire corner under 5.0 emblem: 5"
Rear right/left quarter in front of tire: 6 1/4"
Rear right/left quarter in back of tire: 7.5"
Rear brake light from bottom of painted plastic lip: 11"
**Measurements were taken from the exact middle front/rear, and then where the frame/body ends on the wheel openings.
**Notable that the car is completely even at all measuring points after a year and a half of settling in.
Car: 2016 GTPP
My Steeda Mods:
Stop the Hop Kit
Front 1 3/8" Sway
Rear 1 1/8" Sway
G-Trac Brace
