Steeda Pro Action Shocks Group Buy
Steeda UK
London, UK
www.steeda.co.uk
Mustangs
Hi Everyone. Steeda are proud to announce the launch of our new Pro Action Shocks for the S550 Mustang
Product Benefits
  • Steeda proprietary shock valving
  • Specifically designed for lowered S550 Mustangs
  • Rebound adjustable for the ultimate in tunability
  • Reduce wheel hop, squat, body roll and body oscillation
  • Less damper friction, less sideloading on the shafts, lower internal pressures
  • Huge range of tire, wheel, and spring fitment combinations backed with Steeda’s limited warranty
Searching for the ultimate combination between ride quality and performance for your S550 Mustang? Look no further than our Steeda Pro-Action shocks and struts. These dampers feature street and track-proven technology which have been methodically tested and tuned to achieve optimum compression valving, giving you that quick sports car reaction on the road with easily adjustable rebound damping at the twist of a knob. From soft and comfortable to stiff and aggressive, these Pro-Action shocks have more adjustability than you will ever need!
Incorporate your stock or aftermarket spring package to these adjustable dampers for the perfect ride quality. Eliminate the choppy stock ride, reduce dive, squat and body roll, and eradicate wheel hop once and for all! Steeda’s Pro-Action dampers are the highest quality twin tube dampers on the market, and include a separate compression piston internally to give you the same compression force as a standard damper with significantly less gas and internal pressures - this means less internal stress on the components, less friction, more repeatability and a lighter overall package! Coupled with our extremely strong steel housing, our twin tube setup provides bulletproof reliability, lower bending loads on the damper shafts and increased performance! As always, our kit is backed by our Steeda limited warranty.
This robust system was design to keep your options open. Tire fitment starts at 295 in the front and can go as high as 315 in the front with the correct offset, while 315’s fit easily on the rear. With this range of setup options these, dampers are perfect for daily drivers, road racers and drag racers alike.
Switch to the Steeda Pro-Action shocks and struts for the pinnacle of performance, ride quality and reliability.
Lets get some interest on this and we can get a price setup on the offer, depending on the take up. I cant put anything down as concrete as we will have to make sure the pound isn't worth 0.75c when we execute things, but we will see what we can do!!! :headbonk::confused:
Current retail WAS: £999 inc vat in the UK. We can obviously provide them alongside a set of our springs as well if you want.
Put your names here if (seriously) interested. Also add if you want springs too.
THis offer will run til the END OF JULY in order to get them on the August shipment (allowing for stock in the US, as its a new part and will probably be having a lot of early uptake as plenty of people have been waiting for these bad boys to come out....)
1. Avocet
2. Moz
3. Bronzetooth
4. YOUR NAME HERE! (copy & paste)
  • Like
Reactions: MoZ
