TEXAS HEAT
@tj@steeda is the MAF curve available for those who purchase the intake? This information is important to provide the tuner of our vehicles. Or does Lund already have this?Hello All:
Steeda is happy to announce our latest offering - the Steeda Mustang GT ProFlow Open Cold Air Intake (2015-2020)!
https://www.steeda.com/steeda-555-3228-s550-open-cold-air-intake
The Steeda ProFlow Open Cold Air Intake maximizes the potential of your induction system. Designed by Steeda engineers and put to the test with real track time, this intake will give your S550 an edge. The vehicle-specific design makes use of the factory air duct and draws in fresh and dense air. A roto-molded airbox assembly shields the intake from the hot air of the engine bay and makes sure your 5.0L engine is making peak power. Engineered using CFD (computational fluid dynamics) the intake has been optimized for airflow. Smooth bends and curves in the intake, combined with a high-flow nanofiber mesh air filter, ensure unrestricted airflow. The filter attaches to a specially designed velocity stack that helps to draw in a larger volume of air and increase the speed of air getting pulled into your engine. Steeda's 114mm mass airflow housing is built into the intake tube and generates a clean signal for smooth throttle response and outstanding drivability.
The attention to detail that was put into designing this kit is unlike that of any other brand. Steeda went the extra mile to design the kit to work with the Gen 3 Coyote engine covers so that there is no need to modify or cut the cover. This allows you to maintain that clean look that the stock engine bay has. You have the option to delete the sound tube that sends intake noise into the cabin or delete the sound tube for a quieter cabin.
If you are looking for an intake system that is designed for your S550 by real racers, enthusiasts, and owners of Mustangs, this is the kit for you. Designed, engineered, and manufactured in-house, right here in the USA. With over 30 years of experience racing and building performance parts for Mustangs, you can be sure that Steeda is the name you can trust.
Product Benefits
- Over 30 rwhp and 23 ft/lb tq gain with a tune!
- Does not require cutting of the engine cover
- Prevents heat soak, unlike the factory airbox
- Cools to ambient temperature range significantly faster than the stock unit
- Outperforms all other cold air intakes on the market today
- Installs in the factory location and uses the factory snorkel for easy installation
- Provides the needed parts to keep or delete the sound tube
- Increase in power across the full RPM range, not just peak power
- Lower IAT (intake air temperatures) at cruise when compared to the competition
- Made in the USA
- Lifetime warranty
- Steeda has been building Cold Air Intakes for Ford performance vehicles longer than any other company!
