Lightning Struck
How much do these springs lower a PP2 car?
The sport springs will lower the car 1" Front and RearHow much do these springs lower a PP2 car?
Yeah, I get the difference. They will only install on the car one way, so its it not hard to figure out, but the labeling was confusing. I would have expected it to be labeled based on the side of the car, not the direction of the spring.Hello Rich,
Please give us a call at 1800 950 0774 - Left Hand Wound and Left-Hand side are different in terms of the install.
TJ
We value each and every one of your comments and concerns. The springs are labeled to help our warehouse assemble kits and allows us to identify which direction they are wounded.Yeah, I get the difference. They will only install on the car one way, so its it not hard to figure out, but the labeling was confusing. I would have expected it to be labeled based on the side of the car, not the direction of the spring.
Just for accuracy, mine were also labeled "RHWR” and “LHWR” not "RHWREAR” and “LHWREAR”.We value each and every one of your comments and concerns. The springs are labeled to help our warehouse assemble kits and allows us to identify which direction they are wounded.
As per step 18 in the instructions we explain exactly with labels in which corner each spring goes.
"18. Remove the stock spring. Reusing the upper rubber
spring seat, install the Steeda spring with the tighter
coils to the top, making sure the pigtails of the spring
are in the correct locations. NOTE: The rear springs are
not the same. The spring with the part number ending
in “RHWREAR” is to be used on the driver side and
“LHWREAR” is to be used on the passenger side."
Moving forward, we have caps locked and bolded this step in the instructions to further help in identifying the correct side for the springs. Thank you
Will do, once I find a shop that doesn't want $700 to install them with alignment. I was going to just do it myself, but don't have the tools or patience right now. For now, the springs sit in my garage, taunting me.We have many sets sold ... would love to see some photos!
TJ
Nice - has more drop in the front than I thought it would with the lighter Ecoboost engine.
Yeah, I’d like about another 1/4”. Also have a 1/8” spacer in the back, intended to compensate some, as recommended earlier in the thread. Probably should have gone with 1/4” instead.Nice - has more drop in the front than I thought it would with the lighter Ecoboost engine.
