You look like you probably couldn't drive a soapy stick up wet ass, anyway, so it probably doesn't matter.I am dying waiting for the weather to turn here in the Midwest!
C'mon, Dave, you know who this is.You look like you probably couldn't drive a soapy stick up wet ass, anyway, so it probably doesn't matter.
I am hoping it is Tim, but if it isnt sorry you disapprove of my car handling skills. Just out having fun.C'mon, Dave, you know who this is.
Of course it is! Just messin' with ya.I am hoping it is Tim, but if it isnt sorry you disapprove of my car handling skills. Just out having fun.
So this would eliminate the need for your Front Control Arms Lateral Links w/ Extended Ball Joint (555-4906)?You will still need a bumpsteer kit when you locate to the upper hole for roll center correction. Furthermore, as you can see it has a slot to adjust track width as well. It is held in place with a cam lock.
Steeda Tech
0.014 seconds... seems you need a slightly longer splitter.We wanted to take a minute and post up and congratulate Dennis Healy on his 2nd place finish at the OPTIMA Search for the Ultimate Street Car this month! Only 0.014 sec away from first place! He’s been doing a killer job behind the wheel, and we’re really impressed with how far he’s taken his Steeda-equipped S550!
https://www.steeda.com/dennis-healy-s550-mustang
Thanks Todd! Hurry up and get yours and we will get it up on the rack to change out.This is amazing work @db252 . When I get mine I'm coming over lol!
Thanks for the pics db252.Recently finished getting the Road race K-member in. Weighed both K-members without motor mounts attached or any mounting hardware. Stock is 67.0 and Steeda is 47.9.
You also might spy with your eye a GT500 oil pan that was installed at the same time. I will be putting the belly pan back on but wanted to to show the pics of the full view.
I also have a Whipple setup and with adding this or any other K-member version, you loose one of the isolation points for it IC tank. The tank is completely bolted and supported above it but has a third point for stabilizing and this contact would be rubbing against the bottom lower corner of the radiator since the factory K-member spot is no longer there. Mine is the aluminum version over the plastic style tank and this was my quick fix.
