You will still need a bumpsteer kit when you locate to the upper hole for roll center correction. Furthermore, as you can see it has a slot to adjust track width as well. It is held in place with a cam lock.With the new suspension pick up points, would this eliminate the need for the bumpsteer and roll centre correction kits?
You are correct.I assume you won’t need the Extreme G-Trac brace if you get this K-member?
Thanks I wait for the review of him.We had a customer that was going to install one. It never ended up happening, but he says it would be close given what he has seen.
If we come across more info - we’ll pass it along.
TJ
Final testing will be completed this weekend! We will be doing a couple of races along with a three hour enduro this weekend.Only seeing the drag version on the website. Has this been officially released yet?
With modifications, the belly pan can be used with the Steeda Road K-Member.I may have over looked it, but can you still use the belly pan with this?
I appreciate the fast response! I'm gonna shoot you a message about something else.With modifications, the belly pan can be used with the Steeda Road K-Member.
Best Regards,
TJ
