- Aug 8, 2016
- Pompano Beach, FL
- 2016 Mustang Q750
Production units for final testing on our HPDE and #20 T1 SCCA/FARA Mustang!
Thank you! Yes, the road race production ones will retain the stock track width.Very nice! I'm digging the roll center adjustment! Will you position the optional hole such that it will retain the stock track width (so not just moving up, but also outboard)?
I saved 41 lbs off the front of my car. The k member does not lower the engine, but all the aftermarket mounts that can, fit very well!Weight savings? Does it lower the engine?
Actually, this was pretty easy. I have done a number of F-body subframes. This one was by far a much better job. For one, all the bolt holes lined up perfect. Every piece of hardware was accessable except for the aftermarket swaybar mounts (not sure what's going on there Steeda). I used 3 in ratchet straps off of my strut tower brace. Once the stock subframe was out. I put jack stands under the engine mounts. The hardest part was removing the stock rack and pinion bolts. I had to use my mega breaker bar as my 900ftlb thunder gun barely moved the bolts. All in all at a liesurely pace maybe 4 hours. Wouldn't bother me to do it again.41lbs taken off the front is super! (To me) it looks like it would be a major pain in the *ss to take the other parts off and put this on. I can already see wrenches flying across the garage and the foulest, most ridiculously abrasive language being spewed out at a high volume.
Wow, that's good to hear. So since you did a few in the past on other cars, would you say this would take maybe 6 hours for someone who never did it before?Actually, this was pretty easy. I have done a number of F-body subframes. This one was by far a much better job. For one, all the bolt holes lined up perfect. Every piece of hardware was accessable except for the aftermarket swaybar mounts (not sure what's going on there Steeda). I used 3 in ratchet straps off of my strut tower brace. Once the stock subframe was out. I put jack stands under the engine mounts. The hardest part was removing the stock rack and pinion bolts. I had to use my mega breaker bar as my 900ftlb thunder gun barely moved the bolts. All in all at a liesurely pace maybe 4 hours. Wouldn't bother me to do it again.
