GreenS550
Houghton, MI 49931 Oakland, MI 48363
Bob
2019 Mustang GT Premium 2020 Explorer Limited
I stated some months ago that I wanted to make a comparison between the complete kits of Whipple stage 1 with the supplied Whipple stage 1 tune compared to the Procharger Stage 1 with Procharger's supplied tune. Here is my review so far.
The Whipple setup was on my 2019 Bullitt and the Procharger setup is on my 2018 Mustang GT 10 speed auto. Both cars otherwise stock. The kits were within $100 of each other, so I though it was a goo comparison. I know aftermarket tunes might help, but this is "stock vs stock".
Whipple: Tune spot on. Lower torque. Since it is a manual trans, no opinion on shifting. Started and ran excellent. Intake air temps were only 30-40 F higher than the outside temp. 676 RWHP at 7,800 RPM SAE.
Procharger install was 1/2 the time of the Whipple. Car started and drove like stock except for WOT. In that case, the car acts very weird and lets off at the shift which is very irritating. In higher speeds, the downshift and high rpm shift is good sometimes, but other times the car will stay at a lower RPM like it isn't getting enough throttle. Very weird. I emailed Procharger and they told me to datalog. I asked what PIDs they needed and they told me to look online. In the past tuners told me the PIDs or sent me an email with a file that I attached the datallog to.
The power at 6.50 PSI is not close to the power of the Whipple. The acceleration is smooth and very linear. Intake temps are high in my opinion, about 90F higher than ambient temps.
The quality of the parts are good from both with fairly good install instructions. However the Whipple kit comes with pre-made hoses with OEM style ends and attachments. Since it requires wiring for the intercooler, etc, it is very complete with OEM style snap/click style parts. The Procharger has hoses you cut and I probably used 15 worm style clamps. They work, but more crude.
Summary so far: I like the linear power of the Procharger. I liked the torque of the Whipple, but the Whipple also had it on the upper end. I know some folks will say: "we told you to get the stage 2 kit". I wanted a fair comparison on entry level kits. Perhaps after datalogging the Procharger and a tune revision will change my mind. Still struggling to understand the higher IATs, though.
Soulja4187
Greenacres, FL
David
2021 Mustang GT Premium & 2022 Audi A5 S-Line
If you don't mind me asking how much did you pay to get your whipple and pro charger installed?
GreenS550
GreenS550
Bob
I did both installs myself. The procharger is about 1/2 the time to install. But, it's interesting. After doing both (and a Vortech several years ago: horrible to install on the car I had then), I could do either in a much shorter time. Experience. Beefcake quoted me $1,200 on the Whipple install last year. I was going to have them do it originally, but it was a hassle on the timing and distance.
GreenS550
GreenS550
Bob
On another note, I do not know how good the Whipple tune would have been on an automatic car as far as shifting goes, though.
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
Elaborate more on the Iat issue so we can help you out.
GreenS550
GreenS550
Bob
Since I also have a shifting issue and the car lets off and sits for a few seconds at 4-5K when at WOT, Procharger wants me to do a Datalog, but said for me to check online how to do it and never gave me the PIDs. Another person on this forum gave me suggestions which I will use. When I do the datalog I will pay closer attention to the behavior of the temps and report back. If you have suggestions on which parameters to datalog, that would be very helpful.
Thanks!
Torinate
Ontario
2016 GT Convertible
Yea, those IATs seem high, especially on the Procharger!
Torinate
Ontario
2016 GT Convertible
Thanks. Didn’t realize they got that hot. Looks like he’s running 6.5 right now.
Torinate
Ontario
2016 GT Convertible
Well, maybe not compared to my old Vortech fox body with no intercooler what so ever. But, I would say +90* on 6.5 Psi ain’t great. So on an 80* day, looking at IAT of 170*. Does the tune pull timing at high intake temps and what is that threshold as far as temps?
To me, it seems high.
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
It would be high for that tiny amount of boost pressure. But in the grand scheme of boosted engines and air to air intercoolers, 90 over ambient at the stripe is nothing.
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
Keep in mind when i mention a certain increase over ambient, im talking about WOT at the end of a quarter mile pass. On my car, iat will start at ambient and increase in a linear fashion approx 85deg by the end of the pass. D1x, 1100whp. When ambient temps are low say 50deg, IC efficiency goes up and increase will be less, say 75 ish
engineermike
La
2018 GTPP A10
Most cals, even stock, start reducing borderline knock spark timing at 100 deg F iat However, this is usually misunderstood. Borderline spark timing is when the PCM expects to see knock, but knock retard or advance is still added to or subtracted from that. Borderline knock commanded is also corrected by coolant temp and lambda. If the cal doesn’t reduce timing due to IAT then it would be reduced by knock response anyway. The reduction due to iat just sends it to a more accurate starting point.
The only time the iat correction could reduce power by itself is if you’re achieving max knock advance.
Torinate
Ontario
2016 GT Convertible
Most cals, even stock, start reducing borderline knock spark timing at 100 deg F. However, this is usually misunderstood. Borderline spark timing is when the PCM expects to see knock, but knock retard and or advance is still added to or subtracted from that. Borderline knock commanded is also corrected by coolant temp and lambda. If the cal doesn’t reduce timing due to IAT then it would be reduced by knock response anyway. The reduction due to iat just sends it to a more accurate starting point.
Thanks for the clarification. Much appreciated.
