- Feb 17, 2014
- S550 INTERIOR DRESS UP
- Website
- www.ebay.com
- 03' Cobra, 05' GT, 13' GT, 15' GT
Parts list:
Left toe arm
Right toe arm
Lock nuts
Washers
Tools and crap needed:
-Ratchet
-Socket set (18MM, 21MM, 22MM)
-Adjustable wrenches
Notes:
Alignment is needed after install
1. Remove rear tires.
2. Locate the OEM toe link.
3. Mark the camber adjustment bolt washer so you can line it up when you re-install the bolt. Mark the washer and the mount.
4. Remove the factory toe link
5. Align the new toe link with the OEM and make sure they are the same length.
6. Reinstall in reverse order. Use the supplied washer and lock nut on the spindle side of the toe link.
[/IMG]
Left toe arm
Right toe arm
Lock nuts
Washers
-Ratchet
Notes:
