Springs and Sways Comparison
Hifiguy
Mach 1 Mustang
I have a set of 19x11 wheels for street driving and 18x11 for track use, the base M1 suspension is just not cutting it anymore IMO with the increase in grip.
I would like to car to be a bit stiffer on track and be able to rotate easily, while maintaining comfortable driving characteristics and a minimal drop.
I have made this chart and have been pondering it over for some time.
What setup do I go for? Currently on stock M1 springs and sways.
PP1 w/o MRMach 1Mach 1 HPGT350 (2016-2018)GT350 (2019+)GT350RGT500GT500 CFTP
Front springs165 lb194 lb211 lb194 lb211 lb240 lb251 lb268 lb
Rear springs728 lb657 lb742 lb914 lb857 lb914 lb885 lb942 lb
Front sway32.0mm solid33.3 x 5.0mm wall33.3 x 5.0mm wall34 x 5.7mm wall34 x 4.8mm bonded wall36 x 4.8mm wall36 x 4.8mm wall
Rear sway22.2mm solid24 x 3.6mm wall24mm solid24 x 3.6mm wall24 x 3.6mm wall24 x 3.6mm wall25.4 x 4.5mm wall
OEM Tire WidthF: 255/40R19
R: 275/40R19
F: 255/40R19
R: 275/40R19
F: 305/30R19
R: 315/30R19
F: 295/35R19
R: 305/35R19
F: 305/30R19
R: 315/30R19
F: 305/30R20
R: 315/30R20
F: 305/30R20
R: 315/30R20
Aftermarket options with ~0.75" drop (most I am willing to go)
Ford Perf
M-9602-M
BMR Lowering Springs; Handing versionSteeda Dual Rate Springs & Sways
Front springs250 lbSPH765: 250 lb220-350 lb
Rear springs565 - 1000 lbSPH765: 980 lb800-1200 lb
Front sway37 mm Wall??SB763 Adjustable:
38mm Wall thickness?
SB043 Adjustable:
35mm Wall thickness?
35 mm, Hollow???
Rear sway25.2 mm Wall??SB763:
25mm Wall thickness?
SB043:
25.4 mm Hollow?
Competition sway: 22.3 mm
Drop20 mm
0.787 in
19.1 mm
0.750 in
19.1 mm
0.750 in
I am between just upgrading to GT350R Springs, or M1 HP Springs/rear sways, or the FP kit.
Thoughts?
MarquanTR
Delaware
Marquan
2021 Mach 1
I have the dual rates and competition front and rear sway bars from Steeda and enjoy the feel of the car on the street. I’m running 20 x 11 305/30/20 square.
Mjschneidy
SE Michigan
Michael
2021 Mach 1 HP, 82 GT Track Car, 73 Stroppe Bronco
Thanks for putting that together, I was about to do the same. I have an HP M1 and leaning towards the Steeda dual rates and comp bars. However I see where you could get close by mixing a few of the production parts.
Knockdown
Greg
2021 Mustang Mach 1
Steeda dual rate springs here, softer completion rear sway bar. I made the lower splitter easily removable, take it and the gurney flap off for road trips. For me, this is a really nice setup for a track/road trip car.
Hifiguy
Mach 1 Mustang
For the steeda dual rates, how was the ride compared to stock? The spring rate is pretty high.
The other reason I'm not considering it is the steeda setup seems to be engineered for understeer. I would be increasing the front sway bar size while decreasing the rear sway bar size, a recipe for understeer.
Knockdown
Greg
2021 Mustang Mach 1
For me, dual rates are fine on 12 hour road trips and the weight shift on track was vastly reduced. I don’t notice any understeer on track but I’m only running about 8/10’s, just having fun at Sebring.
shogun32
Northern VA
Dual rate front springs, Steeda front bar. Magneride controller with either canned Steeda tune or write your own. That's where I would start.
Or convert your front mag ride shocks to use coilovers springs.
