honeybadger
Just don't care
Or the $65 grimmspeed modules. They will keep them always open/close as well.
Well, then, that's interesting. That configuration doesn't come with the switch that's causing trouble, so it's already double-turned off.I have the base which was a 4inch screen, was tiny, and i had a 10 digit keyboard that looked like an old telephone, i wanted better tech in the car...
I have the OEM Sync 3 system installed in mine, I have never had any issues. Everything works like factory buttons, Auto A/C and everything else. Look up infotainment.com they have the full OEM Sync3 upgrade kit.Yea, Ford has a TSB about people upgrading from Sync to Sync3 having issues even though everything is installed by the dealership. Nothing is 100% except buying a GT350 with Sync3 from the factory. I've just accepted that I'll only have Sync in my car.
Does that include working exhaust valve toggle and functioning dual zone climate control? Those were the two areas that seemed to cause issues.I have the OEM Sync 3 system installed in mine, I have never had any issues. Everything works like factory buttons, Auto A/C and everything else. Look up infotainment.com they have the full OEM Sync3 upgrade kit.
I'm pretty sure that Infotainment dot com enables the exhaust valve toggle and the proper function for the hazard flashers.Does that include working exhaust valve toggle and functioning dual zone climate control? Those were the two areas that seemed to cause issues.
Everything works. The toggle for exhaust works, and the A/C control works as well. I don’t think it actually does dual zone, but you can definitely adjust dual zone temperature in the screen. I programmed everything with Forscan, so everything works. If you get the kit from Infotainment.com they will give a little programmer that automatically programs the computer to work with the toggles and controls.Does that include working exhaust valve toggle and functioning dual zone climate control? Those were the two areas that seemed to cause issues.
Yes.Thanks for the info, i didnt have the toggles originally tho, so the toggles would work as if it came with them?
