Thanks, do you have a recommended brand? I found some on amazon but I dont think they have the correct hub bore, but I did find some on Ebay that should work.OEM PP1 rears need a 5mm spacer to be used on the front. Get a hubcentric one, the generic ones are not confidence inspiring.
I think I got mine on ebay too.Thanks, do you have a recommended brand? I found some on amazon but I dont think they have the correct hub bore, but I did find some on Ebay that should work.
Yeah, if that's the case. Going to need at least a 10 to 15mm spacer.I thought PP1 rears were like +52 offset. If so I can see why the 5mm spacer isn't enough.
