Sound tube delete
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
Just did this today to try. I only pulled the front half off and capped both ends to make sure I like it before permanently ripping it out. So far so good! There's a little less volume in the cabin, but now I can hear the exhaust better. Bonus find: initial tip-in throttle response is improved some.
justinakajuice
Chantilly, VA
2016 GT Prem. Auto
Honestly, I haven't even opened the hood on the '16 yet.
Duttch
Fuquay Varina, NC
2015 Mustang GT (Guard color)
Ppfffff That bastard tube is out by using a 10mm ratchet wrench.
The delete took me about 15 minutes a couple of times my wrench went down.
I did attached a small rope on the end of the wrench to pull it up.
It also helps to pull the dip stick and put your through the opening behind the brake lines.
The plug was easier if the tube is out you have more space.
Duttch
Fuquay Varina, NC
Yep, i did notice that throttle response is improved.
And a much cleaner sound in the cabin.
Glad that i did this mod.
BmacIL
Enginerd
Naperville, IL
S550VIN54
Raleigh NC
Stephen
2021 FJG Mach 1 HP
Guys,
I must say after reading all the post it has totally amused the living hell out of me into writing a satire using the jargon's illustrated here. You guys rock and that is why I bought another mustang!:cheers:
Dragster
2015 GT PP
What is the diameter of the hole in the firewall that needs to be plugged after the sound tube is removed? Thanks in advance for the help!
GT Pony
Pacific NW
Zodiac
Sarcasm Personified
Cary, NC
2017 Charger R/T Scat Pack
I wanted to thank those who suggested to go hulk on this. When installing my CAI I got frustrated on trying to reach the nut, and said fuck it. I went from sound tube to sound tube delete in 4 seconds. Nothing more gratifying than that.
S550VIN54
Raleigh NC
Stephen
2021 FJG Mach 1 HP
Wasn't that just about the most irritating thing you have dealt with in your life. Seems you dealt with it the way I wished I had. I ended up using a 10 mm box wrench and yes it took some time but wasn't it nice to see that hideous thing removed. There is no doubt the engineers meant for this to stay on.
The boss was 100 times easier than this and with that being said tells me that there was a different design engineer involved with the 2015.
:cheers:
GT Pony
Pacific NW
:cheers:
Yes, a very sadistic design engineer.
IvanCRF
El Paso, Texas
5.On'ry
