ridenfish39
- Feb 25, 2015
- Philthydelphia
- 2015 Guard GT PP
Some of you must be power lifters, because I yanked hard and that tube won't budge. Lol.
It's a 10mm. Use a normal 1/4" drive and a deep-well 10mm. The delete took me about 3 minutes. It helps to pull the dip stick and put your through the opening behind the airbox/intake and the brake lines.What size nut is holding the firewall side of the tube in place? ...cuz I want to head down in there with the correct size!
Sent from my SCH-I545 using Tapatalk
If any normal sized human can get that nut off on the PP without removing the strut tower brace and/or the K brace I will be extremely surprised. I was determined to get it off and after about 30 minutes of trying i ripped the damn thing out. I also removed the gas pedal with three nuts from the inside and plugged the hole from that side as getting my hand to the hole on the engine side was impossible.^Good point on the PP brace. Didn't have to worry about that. Even with that, I'm pretty sure you can still go the same route that I went to get that nut.
Heh. Hehe.
If you don't have to the tools or patience, definitely rip that b**** out. Wish I'd known to rip it out before opening my tool boxes and devising a strategy to get in there. I'm almost positive that it's a nyloc nut, so it won't go anywhere after ripping off the sound tube.I pulled it out on my non-pp just because I struggled for like 15 minutes trying to reach the nut and ended up losing my patience.
Closed it with the kit that comes with the JLT CAI.
