Some observations fighting IAT's with JLT CAI
Discussion in 'V8 5.0L Engine / Mods: Bolt-ons, Exhaust, Tuning' started by pgonza2723, Jul 12, 2019.
  1. Zelek
    Zelek Well-Known Member
    First Name:
    Vehicle(s):
    2017 Mustang GT Premium PP, 2018 Honda Accord Touring 2.0T
    Feb 11, 2016
    Austin, TX
    2,710
    1,388
    Rating:
    100%
    2   0   0
    Yeah, you at least need a 2018 manifold and taking your rpm's above 7500+ to really see any small difference between stock and the aftermarket cone style filters. Even then, we're not talking a lot of power. The cost per performance just really isn't there.
  2. OneFordGT
    OneFordGT Well-Known Member
    Vehicle(s):
    16 GT
    Mar 21, 2016
    Ohio
    210
    65
    0   0   0
    #32 OneFordGT, Jul 16, 2019
    This helped me a lot.
    rmreid17, BlownGP and Bluemustang like this.
  3. BlownGP
    BlownGP Well-Known Member
    First Name:
    Steven
    Vehicle(s):
    Pontiac, Ford, Dodge
    Jan 25, 2016
    Houston/Baton Rouge
    850
    182
    0   0   0
    OneFordGT likes this.
  4. rex979
    rex979 New Member
    First Name:
    Doug
    Vehicle(s):
    2017 Mustang GT premium convertible
    Mar 25, 2019
    Winnipeg
    This is one of the reasons why I decided to go with the Holley Intech system instead. It's a true cold air intake system. Also their dyno claims are impressive but I have not personally validated them. From reading other Forums and other articles posted it would seem Holly's claims are pretty close.
  5. BlownGP
    First Name:
    Steven
    Vehicle(s):
    Jan 25, 2016
    Houston/Baton Rouge
    850
    182
    0   0   0
    That's a weird looking intake, but I can see how it would keep the IATs down.
  6. Zinc03svt
    Zinc03svt Well-Known Member
    Vehicle(s):
    stang
    Jun 3, 2018
    usa
    2,311
    1,200
    0   0   0
    I hit 138 iats today stock box. Heat index 105 sitting in line for 15 minutes in Wendy’s drive-thru. Two blips down the road back down to 109. On E85 there is zero heat soak nor timing pull. Next...
  7. BlownGP
    First Name:
    Steven
    Vehicle(s):
    Jan 25, 2016
    Houston/Baton Rouge
    850
    182
    0   0   0
    Heat index is what it feels like not what the actual temperature is
    But I assume with that heat index, the ambient temp was around 95 because that's what it was here today with similar heat index.
    So was 109 IATS is about average.
  8. WhiteyDog
    WhiteyDog WOOF!!!
    Vehicle(s):
    '16 GT PP
    Jun 30, 2016
    Manheim, Pa.
    1,738
    681
    0   0   0
    I won't get as close with the IAT's as you N/A guys, my IAT is measured post supercharger (IAT2). So I made a lid for my JLT and did 20190705_115406.jpg 20190705_115510.jpg some other things. Every little bit helps.
    BlownGP likes this.
  9. Zinc03svt
    Vehicle(s):
    stang
    Jun 3, 2018
    usa
    2,311
    1,200
    0   0   0
    Yeah around 95 and humid. Had a/c running whole time. I had never seen much past 125 before sitting for long periods of time. Again, the E85 and once moving a tad it is not an issue. CHT’s were 199-204.
    BlownGP likes this.
  10. Zelek
    First Name:
    Vehicle(s):
    Feb 11, 2016
    Austin, TX
    2,710
    1,388
    Rating:
    100%
    2   0   0
    I've been pretty satisfied with my CP-E Icebox so far. IAT's are at the stock level with a tune required intake, dry flow filter. It's getting to be 100 degrees here in Texas and my IAT's are about 3-4 above ambient when I'm really moving and sit about 8-10 degrees above in city driving. I've gotten up to about 120-125ish while idling for a while, but like everyone else has said before, it recovers quick after you're moving. It's just good to have that extra insulation so you don't hit those 140+ degree temps from idling too long with an open intake during the summer. Even then, your car will still be fine. It takes a while to hit those temps without FI.
  11. Nuked
    Nuked Well-Known Member
    Vehicle(s):
    2016 Triple Yellow GTPP w/Recaros
    Sep 15, 2015
    Morgantown, WV
    693
    231
    Garage Profiles:
    Actually you could simply throw in the MAF curve for the JLT, leave all other parameters the same then dyno. It can be done, reason it hasn't.... likely results wouldn't sell 350.00 intakes.
    Kermitz and smoke_wagon_6g like this.
  12. AceOne
    AceOne Well-Known Member
    Vehicle(s):
    1985 Mustang GT, 2005, 2011, 2016 Mustang GTPP (Code_Blu), 2016 GT350R (Bloo-Doo)
    Jan 8, 2016
    TX
    116
    94
    0   0   0
    Modified the 2015 GT Airaid kit to work with the CJ manifold and FRPP Maf tube...dropped idling ait by 40* 20181008_195556.jpg 20180830_201836.jpg
  13. AZ18yote
    AZ18yote Well-Known Member
    First Name:
    Bryan
    Vehicle(s):
    Nov 24, 2017
    Arizona
    1,788
    654
    Occupation:
    IT Systems Engineer / Consultant
    0   0   0
    Was 115 here in Phx the other day. Stock box IATS around 121 sitting at red lights and in traffic. "Cools" right off when moving. CHT in that similar 196-204 range. That's just on flex fuel not even full e85 (damn AZ). E + stock box is a winning combo in hot conditions imo.
    Zinc03svt likes this.
  14. Burkey
    Burkey Well-Known Member
    Vehicle(s):
    Feb 9, 2016
    Australia
    3,334
    1,738
    Garage Profiles:
    Water/meth won’t alter the way the ECU perceives IAT on a NA car.
    The MAF sensor is upstream of the spray, ergo, the IAT reading will remain the same.
    You might see some extra spark though if you get an octane bump.
  15. Burkey
    Vehicle(s):
    Feb 9, 2016
    Australia
    3,334
    1,738
    Garage Profiles:
    Good work, but you’d be surprised how much air-gap there is in the bit you missed.
    See pic for how to rectify if you’re interested. BFD85E19-9849-4F8F-A96D-6F20D50DF4EF.jpeg
Loading...
Share This Page
