kcline145
Compression test came back just fine everything was between 220 and 230psi. Bore scope looked good too no excess wear or scoring at all. Cylinder 8 had some oil or fuel i couldnt tell but there wasnt much of it. Nothing looked concerning at all so im just gonna run the piss out of it until it blows up then build a motor lol. Ill leave a picture of the oil/fuel whatever.The 2k rattle is typically only associated with the 2018+ MY. Note I said typically. But to answer your main question, no I don't. My engine sounds very healthy building up speed. It sounds the worst at idle. The problem with "rattle" is that it's a vague description with multiple symptoms sharing a similar sound. The steps you're taking are what I'd do if I was worried. I'd also start logging to make sure it's not pinging you're hearing.
