Signature Wheel’s GT500 Adventures
50 Deep
50 Deep
Signature Wheel Ford Rep
Gold Sponsor
Sacramento, CA
www.signaturewheel.com
2017 GT350R
As an owner of 21s, get the 20s.
@P4mnceblue82
There should not be any issues with the 21” setup unless you are running a larger front tire. The 305/30/21 rubs because of the tires height, not due to the wheel. You want to step down to a 295/30/21 Pilot 4s that we recommend if you want no rubbing on the fender liners or need for modification.
Shelbeast
Virginia (DMV)
RAJ
GT500, MME-GT, BMW X-1
@P4mnceblue82
Thanks for the additional info. I will def. look at 295 on my next set. 305s just look so damn good. What is best for rear?
Jmeo
You said member ;)
Massachusetts
Jaime
2020 GT500, 2022 F150 PowerBoost
Good data to share.
it should be noted The 21” front rubbing was a result of the 305/30/21 tire being used though. With the recommmended 295/30/21 tire the rubbing issues don’t occur. That setup looks fantastic and works great
You are correct, the 295/30/21 will fit. This brings me back to the sucky tire size selection for 21" wheels.
There was no MPSS 4s 305/30/21 (at the time of my purchase anyway) so it was either tire down (295) or tire up. This is why I went with the 315/30/21 (not 305).
Personally, I do not want to tire down just to fit a specific wheel. I would prefer to stay with a wheel that will at the very least allow me to stick with the stock 305 front width.
Disclosure: This is at no fault of the wheel, and admittedly a personal preference.
50 Deep
50 Deep
Gold Sponsor
Sacramento, CA
2017 GT350R
White gold.
20” Signature Wheel Precision Series SV705 look right at home on Nicholas’s 2020 GT500.
Finished in the classic Brushed Triple Black Tinted.
50 Deep
50 Deep
Gold Sponsor
Sacramento, CA
2017 GT350R
Rear we can go 325 or 315.
50 Deep
50 Deep
Gold Sponsor
Sacramento, CA
2017 GT350R
That 305 did look good.
Jmeo
You said member ;)
Massachusetts
Jaime
Thanks. 305/325 next time. Mispoke on the 305 (have 315),
That’s the problem, thy don’t make a 305/30/21 4S tire. You have to go bigger or smaller.
Jmeo
You said member ;)
Massachusetts
Jaime
Oh, ok. might do 295 then. Wheels are holding up nicely and still fresh
With all the work I did on the splash shields I sent you, are you getting some rubbing? I didn’t have any rubbing after doing those and trimming the little bracket behind the wheel (under the splash shield).
Shelbeast
Virginia (DMV)
RAJ
Just a little when making a full hard right. Wish i kept my old splash shields. Was moving at the time and ditched them.
Sins550
GA
2015 Mustang 5.0 PP
These drag packs don’t get caught slipping.
20x11 / 18x11 square Signature Wheel Track Series SV502 built for Dennis’ 2020 Shelby GT500.
Finished in Gloss black with Exhibitions Of Speed bead lock enhancement.
What size tire in the rear?
50 Deep
50 Deep
Gold Sponsor
Sacramento, CA
2017 GT350R
Only the best for your Shelby.
20x11 / 20x11.5 Signature Wheel Attack Series SV602 built for Thomas’ beautiful 2020 GT500.
Finished in Brushed Aluminum for a perfect compliment to the white stripe. The Attack Series requires a slightly more aggressive fitment on the GT500, but we have the recipe to make it work.
Sins550
GA
2015 Mustang 5.0 PP
Can the beadlocks be fitted to the SV602s on the blue car? And what size tires are on the car I quoted in my last post above this one?
