Short Shifters. Steeda vs MGW vs Ford Performance
Skyscraper
Sydney
Mustang - Magnetic Manual
Hi all
I'm looking at getting a short shifter just not sure what one.
I'm leaning towards the Ford performance one just to keep with the Ford theme.
Just want to know if anyone has a short shifter and what brand they used and how much did they pay for both the parts and install.
I've heard Steeda's are great but can allow a bit of heat into the car.
MGW's sound good too.
Just like to get your guys feedback.
Thanks
Aus-MustangGT
Aus-350
Australia
'15 WRX/Evo 8 ADM
Hi all
Thanks
I did a lot of research on this and landed on the MGW shifter so that is where my bias is.
Ford peformance: honestly I wouldn't recommend it as it isn't a true short shifter, it won't help with high RPM lockouts it just alters the fulcrum point
Steeda: It came out after I purchase the MGW, seems to be a capable unit, appearance wise looks similar to Barton.
MGW: Probably my favourite mod, amazing shifter, it can rattle though on constant high rpm runs when it heats up though which is a negative.
What I would strongly recommend though, is wait until you have the car and see if you like it or not. Some users seem to get better transmissions than others.
Skyscraper
Sydney
Thanks for the info.
I have my car already and the shifting is OK. I get the occasional high RPM lockout.
With the MGW shifter do you push down and up for reverse ? and what did it cost you for parts and install ?
Thanks for your help
msweet
Sydney
2019 Ruby GT PP 10A w/ Magride, Recaros
Yeah, I second [MENTION=14692]Aus-MustangGT[/MENTION]'s sentiments. MGW is great. No lockouts, push down reverse
I think I paid around $800 delivered for the shifter, install was around $450-500 I think, but had other stuff installed at the same time (AUD).
Burkey
Australia
Have you considered swapping out the engine mounts? Much cheaper than a shifter and much easier to install. Less engine twist, less lockouts.
Voodooo
SE Michigan
Scott
Carroll Shelbys Soul Lives Under My GT350 Hood
Ummmmm this is a no comparison. MGW RULES! Hands down.
Since-64
Australia
Graeme
2014 Grand Cherokee, G6ET, 2016 Mustang
MGW all the way. I paid approx A$740.00 delivered with adapter to keep original knob. If your handy with spanners you can fit in about 3-4 hrs. Not too hard an install just not a lot of room to move.
Malibu1
Malibu
Sydney
Mustang GT Magnetic
Happy with my Ford Performance shifter but probably had a decent transmission to start with. In 4th can hear some vibration come through but no lock outs ever. No idea on other brands and unfair to comment on them as have no experience with them.
FIXR7
Perth, Western Australia
Peter
'93 Range Rover Rogue 351 powered, '17 Ruby GT, '99 XH V8-S ute, '69 Mercury Cougar XR7 S-code, '96 XH Ex-pork van
I'm looking at a Barton shifter.
msweet
Sydney
MGW + BG synchroshift II = Heaven
stasik-a4
SE Melbourne/Australia
2017 GT PP1
Liber
Darwin
2016 Magnetic GT - 1971 XY GT
Burkey, have you got the UPR street mounts in? How are they?
BroncosXR8
Sydney
EL II XR8, 2015 Mustang GT on the way!
I have the Ford Performance shifter as well. Since I was at Herrod's getting a bunch of other Ford Performance kit fitted at the time I chucked on the shifter as well, cost me $650.
I also had the Steeda transmission insert installed at the same time, which I wouldn't recommend as it has definitely increased vibration coming up through the cross member into the tunnel.
On the shifter itself I don't have any problems with it, it is by far much stiffer and solid then the standard, it uses a metal bearing rather then the stock plastic one, much shorter throw too. On my track day where I was really getting onto it there were no missed shifts or lockouts.
Although I'd probably go the MGW, but I decided to keep it all FP branded gear.
