Zitrosounds
- Oct 20, 2015
- Madison, AL
- Harold
- 16 GT350R/16 GT350TP/15 GT-PP/12 GT-PP
Is this a wrap or a matte clear plasti dip????Good evening fellow enthusiasts and Shelby GT350 owners. We wanted to make this thread because we have been getting a lot of phone calls and tons of requests via Mustang 6G forum and media channels in regards to different size options available and also what the numbers look like in each fitment.
Currently available are the R-spec 19x11.0" front and 19x11.5" rear. We recently fitted a 19x11.0" front and 20x11.0" rear, and furthermore we have had requests for a 20x11.0" front and 20x11.5" rear which Bulter Tire has fitted with Vossen forged wheels.
Considering that all three setups have been done and nice photography is available at difference angels, this would be a great place to make your comparisons.
We wanted to bring it in all one place and provide every single detail for each specific setup. We did not leave any information behind, we have done the homework so you don't have to.
We value all of your opinions and appreciate the feedback we have been receiving since day one on this awesome forum. It is for that reason that we want to bring everyone's thoughts, ideas, opinions, concerns, comments, and preferences in one place. Please take a moment to go through the different fitments and images and cast your vote. We have used this same process up to this point in manufacturing Project 6GR wheels, and now we want to focus in on the exact fitments enthusiasts want for their Shelby cars.
Thank you again for your feedback, we appreciate it and put it work in delivering exactly what you want. :cheers::cheers:
We are including the factory OEM Ford Shelby GT350 wheels as a starting reference point in the plus sizing process.
Factory OEM Ford Shelby GT350 Wheels
Front Wheel: 19x10.5 30mm offset weight is 31lbs. (30.95lbs. to be exact)
Rear Wheel: 19x11.0 62mm offset weight is 31lbs. (30.85lbs. to be exact)
Front Tire: 295/35/19 Michelin Pilot Super Sport
Front Tire: Section width: 11.9" | Tread width: 10.0" | Overall diameter: 27.1" | Revs. per Mile: 767
Rear Tire: 305/30/19 Michelin Pilot Super Sport
Rear Tire: Section width: 12.3" | Tread width: 11.0" | Overall diameter: 27.4" | Revs. per Mile: 758
19/19" Fitment option #1
Project 6GR R-spec wheels 19x11.0/19x11.5
Front: 19x11.0 24mm offset weight is 27.4lbs. (Reduction of 3.6lbs. off of front factory wheels)
Rear: 19x11.5 56mm offset weight is 24.7lbs. (Reduction of 6.3lbs. off of rear factory wheels)
Total of 19.8 pounds of unsprung rotational mass.
19/20" Fitment option #2
Project 6GR R-spec wheels 19x11.0/20x11.0
Front: 19x11.0 24mm offset weight is 27.4lbs. (Reduction of 3.6lbs. off factory wheels)
Rear: 20x11.0 50mm offset weight is 26.1lbs. (Reduction of 4.9lbs. off factory wheels)
Rear Tire: 305/30/20 Michelin Pilot Super Sport
Rear Tire: Section width: 12.3" | Tread width: 11.8" | Overall diameter: 27.2" | Revs. per Mile: 764
Total of 17.0 pounds of unsprung rotational mass on all four corners.
20/20" Fitment option #3
VOSSEN Forged: CG-Series CG-205 20x11.0/20x11.5
Front: 20x11.0 n/a mm offset weight is n/a lbs. (Reduction of n/a lbs. off factory wheels)
Rear: 20x11.5 n/a mm offset weight is n/a lbs. (Reduction of n/a lbs. off factory wheels)
Front Tire: 295/30/20 Michelin Pilot Super Sport
Front Tire: Section width: 11.9" | Tread width: 11.5" | Overall diameter: 27.0" | Revs. per Mile: n/a
Total of n/a pounds of unsprung rotational mass remove on all four corners.
**n/a - We will update this information as soon the information is available.
In case you wanted to go wider, here is another option available, not for the faint of hearts.
Front Tire: 305/30/20 Pirelli Pzero Corsa System (Streetable Track & Competition)
Front Tire: Section width: 12.3" | Tread width: 11.5" | Overall diameter: 27.2" | Revs. per Mile: n/a
Rear Tire: 315/30/20 Pirelli Pzero Corsa System
Rear Tire: Section width: 12.6" | Tread width: 11.4" | Overall diameter: 27.5" | Revs. per Mile: n/a
Fitment Upgrade Option # 1 --- 19x11.0" front & 19x11.5" rear | Michelin Pilot SS 295/35/19 & 305/35/19
Wheels Installed by Need 4 Speed Motorsports in Los Angeles, CA
Fitment Upgrade Option # 2 --- 19x11.0" front / 20x11.0" rear | Michelin Pilot SS 295/35/19 & 305/30/20
Fitment Upgrade Option # 3 --- 20x11.0" front / 20x11.5" rear | Michelin Pilot SS 295/30/20 & 305/30/20
Wheels Installed by Butler Tire in Atlanta, GA
DAMN!!!!!!!
