S550 Mustang Seat Track Adapter
BKauto
Bethlehem, PA
www.bkauto.com
2016 Performance Package Mustang GT
The Brey-Krause Safety System
These products are designed and engineered to function together as a complete safety system -- first locating the driver in the car and second reinforcing the structure around the driver. A system is only as good as the weakest link which is why we highly recommend only using Brey-Krause products.
All Brey-Krause harness mounts have been tested and certified by an independent lab to handle the forces required by the National Highway Traffic Safety Admin. DOT and SAE J385 Rev. MAR 95, Motor Vehicle Seat Belt Anchorages-Performance Requirements.
R-9184 / R-9185 Seat Track Adapter (Drivers/ Passenger Side)​
This Seat Track Adapter offers an innovative solution for aftermarket seat installation in S550 Mustangs. This adapter is the platform for a complete seat assembly offering simple installation, adjustment, and flexibility. These adapters bolt to the factory mounting holes and place the seat in the lowest possible position the car. This lowers the center of gravity, reduces weight, adds room helmet, and gives the driver better connection to the car with more feedback through the seat.
The R-9184 & R-9185 Seat Track Adapter works with a plethora of Brey-Krause side mounts allowing for the installation of seats from various manufacturers. Using our side mounts, seats can be mounted to Recaro sliders (which we always recommend using) or directly to the floor for an even lower, stronger, and better connection to the car.
This product also has provisions for a sub strap mount and lap belt mounts (sold separately). This properly locates the sub strap and lap belts below the slider with various positions for 5 and 6-point harnesses and does not inhibit use of the stock 3-point seat belts.
Additional products are required to complete the seat mount setup.
Side mounts (parts listed below) and Recaro sliders (part# 0.20.40) allow the seat to be readily adjusted for more than one driver. If seat adjustment is not required we recommend installing side mounts directly to the seat track adapter for better positioning and lower center of gravity. The side mounts listed below were designed to work specifically with the seat indicated however they are compatible with a variety of other seats not listed. To determine compatibility please see mounting dimensions on the "Additional Description" tab on our website or feel free to call us at 610-867-1401 or email at [email protected].
R-9186 Sub Strap Mount (only for R-9184 & R-9185)​
This product mounts and properly locates the sub strap for 5 and 6-point harnesses. Multiple mounting holes allow the belts to be properly aligned with various seating positions.​
(Product pictured is a prototype the production model will be slightly different in how the sub strap mount (sold separately) will attach.)
