RPM keeps climbing with no throttle?
Discussion in 'Forced Induction - 5.0L V8 Engine' started by ForYourOwnGood, Jun 26, 2019.
  1. OP
    ForYourOwnGood
    ForYourOwnGood Well-Known Member
    Vehicle(s):
    2017 Grabber Blue 5.0
    Jun 28, 2016
    Central MA
    1,400
    611
    Rating:
    100%
    1   0   0
    No I was careful not to move it at all. I know better than to damage those diaphragms.
    OEM throttle body, yes catch can and no long tubes. I have a tune revision that disables the rev hang I just haven't had a chance to get it flashed yet. This effect only happens some of the time so its really hard to pin down. I have checked for vacuum leaks and had it smoked, my buddy has one of the smoke generators and plug kits. I'm also not getting any symptoms of unmetered air in the system at all.
  2. aleccesarenriquez
    aleccesarenriquez Well-Known Member
    First Name:
    Alec
    Vehicle(s):
    2017 GT PP
    Mar 19, 2018
    San Antonio, TX
    403
    125
    Occupation:
    Engineer - Med Devices
    Rating:
    100%
    1   0   0
    DId you ever figure out the issue? I'm having this exact same issue right now. Log looks identical
  3. aleccolin
    aleccolin Well-Known Member
    First Name:
    Colin
    Vehicle(s):
    2016 GT PP
    Jun 7, 2017
    VA
    604
    189
    Rating:
    100%
    1   0   0
    Can you log throttle plate position also?
  4. aleccesarenriquez
    First Name:
    Alec
    Vehicle(s):
    2017 GT PP
    Mar 19, 2018
    San Antonio, TX
    403
    125
    Occupation:
    Rating:
    100%
    1   0   0
    Do you know what that pid might be called? Don't really see any mention of a throttle plate position in the ones I have listed.
  5. aleccolin
    First Name:
    Colin
    Vehicle(s):
    2016 GT PP
    Jun 7, 2017
    VA
    604
    189
    Rating:
    100%
    1   0   0
    No, but I think they're called Throttle Angle and Throttle Angle Desired (?)
  6. aleccesarenriquez
    First Name:
    Alec
    Vehicle(s):
    2017 GT PP
    Mar 19, 2018
    San Antonio, TX
    403
    125
    Occupation:
    Rating:
    100%
    1   0   0
    Doesn't look like Lund included those pids in their config file. Be interesting to see if the throttle body is actually getting stuck open like that.
  7. Burkey
    Burkey Well-Known Member
    Vehicle(s):
    Feb 9, 2016
    Australia
    3,333
    1,736
    Garage Profiles:
    Here’s one of my logs from a Lund tune. Note the selected PIDS (rpm, pedal and throttle blade).
    Here’s the thing:
    I distinctly remember this particular log and how I had to pedal it a bit at the top of third gear.
    You can see me dancing on the throttle to straighten the car up, but according to the log, the throttle blade remained wide open (it absolutely did NOT remain wide open).
    I can’t explain what’s going on here. 120900D5-49FC-4FFD-8469-21FA91AD5EBD.png
  8. Avispa
    Avispa Well-Known Member
    First Name:
    Richard
    Vehicle(s):
    2016 Mustang GT/CS convertible
    Dec 5, 2019
    Oldsmar, FL
    328
    185
    0   0   0
    Faulty throttle position sensor maybe. Its the only way the PCM knows where the throttle really is. An intermittent sensor might not throw an error code.
    You'd think after 15 years with electric throttles thus kind of stuff wouldn't happen but....
    aleccesarenriquez likes this.
  9. aleccesarenriquez
    First Name:
    Alec
    Vehicle(s):
    2017 GT PP
    Mar 19, 2018
    San Antonio, TX
    403
    125
    Occupation:
    Rating:
    100%
    1   0   0
    Didn't know ETC_ACT was throttle angle. Here is that same log. Looks like throttle closes a little bit after I left off but for some reason rpm spikes to over 8100 anyways. Throttle angle seems to decrease too so it's not getting stuck open either.
    Looking at your log shows an even more substantial throttle delay. Have you tried to resolve that or have you just made it an afterthought? I did notice your rpms fell accordingly when you did let off. Mine just sky-rocketed.
    Lund did get back to me and said the behavior was normal. Not entirely convinced yet.
  10. Burkey
    Vehicle(s):
    Feb 9, 2016
    Australia
    3,333
    1,736
    Garage Profiles:
    That’s the weird part, there is NO delay in reality. Not sure why the log shows what it shows. I clearly remember having to get off/on the juice to straighten it up, along with the car doing as a I’ve asked (as you can see with the rpm change).
    If you look at it carefully, you can see where the wheel spin started, my reaction on the pedal, rpm dropping cos it hooked again, me having another gentle stab at it and then giving up.
    I’ve highlighted (in red) the bit where I’d say I’ve “called it” and the bit where the ETC_ACT decides to drop off. The time difference between those event is 0.12 seconds.
    The interesting part to me is that the ETC_ACT doesn’t move at all until the pedal is at 3%.
    I can’t explain any of it. The car drives just fine, no hang, nothing of the sort.
    It’s as though the PID isn’t grabbing the data correctly for whatever reason. BA264072-26AA-488D-865C-F75E602CBF6D.jpeg
  11. aleccesarenriquez
    First Name:
    Alec
    Vehicle(s):
    2017 GT PP
    Mar 19, 2018
    San Antonio, TX
    403
    125
    Occupation:
    Rating:
    100%
    1   0   0
    Might be due to a slower sampling rate from the throttle sensor?
    My issue is a little bit different though. Your rpm seems to respond fine to letting off, while mine wants to go to the moon.
  12. aleccolin
    First Name:
    Colin
    Vehicle(s):
    2016 GT PP
    Jun 7, 2017
    VA
    604
    189
    Rating:
    100%
    1   0   0
    How are your BOVs plumbed? Are they venting to atmosphere? Where is the boost/vac reference coming from? You don't have a check valve in the boost reference line, do you?
  13. Burkey
    Vehicle(s):
    Feb 9, 2016
    Australia
    3,333
    1,736
    Garage Profiles:
    I think you’re dead-on. Even when the pedal goes WOT at the start, you can clearly see the lag in response of the etc PID. Seems that it’s not the most reliable source of data.
  14. aleccesarenriquez
    First Name:
    Alec
    Vehicle(s):
    2017 GT PP
    Mar 19, 2018
    San Antonio, TX
    403
    125
    Occupation:
    Rating:
    100%
    1   0   0
    They are routed off the vacuum block, along with everything else. No check valves
Loading...
Share This Page
