RPIDON
2015 Ford Mustang GT Eibach Spring Pro Kit 35145.140
Set of Four Eibach Pro-Kit Springs for 2015 GT Mustangs.
If you want your 2015 GT Mustang to stand apart from the rest of the herd, grab your Set of Four Eibach Pro-Kit Springs for 2015 GT Mustangs from CJ Pony Parts today. This awesome spring system will dramatically improve your Mustang’s performance while simultaneously providing a new and aggressive stance!
Eibach Pro-Kit Springs Features and Benefits:
- Proprietary, Progressive Spring Design
- 1.1”-1” Drop for GT Fastback Mustang
- Lower Center of Gravity
- Reduce Squat During Acceleration
- Limits Excessive Nose-Dive When Braking
- High Performance and Fierce Appearance
- Reduces Body Roll While Cornering
- Excellent Ride Quality
- Corner Faster, Stop Quicker and Handle More Precisely
- Improved Aerodynamic Efficiency
These springs will reduce squat during acceleration, limit nose-dive while braking, reduce body roll during cornering and maneuvering and also reduce excessive fender-well clearance, making your Mustang look just as impressive as it performs. By using an advanced proprietary, progressive spring design, these performance springs provide the ultimate balance to take your passion for driving to a whole new level. The lowered ride height helps to distribute stress evenly and provide an improved ride quality. When combined with Plus-1 or Plus-2 wheels and tires, the Eibach Pro-Kit Springs become that extra special touch for great, all out performance and appearance results in your 2015 GT Mustang!
The ride height will move a welcome 1.1” lower towards the ground when you install these high-quality Eibach Pro-Kit Springs for 2015 GT Mustangs. As everyone has learned from racing and independent testing, lowering your vehicle’s ride height improves the aerodynamic efficiency by forcing more air over the car and less underneath, where most of the drag is found, resulting in higher top speeds on the track and better MPG on the highway.
Item # 35145.140
Website Link : http://www.rpidesigns.com/shop/item.aspx?itemid=5208
Item # 35145.140
