ROUSH 20" x 9.5" Aluminum Wheels Now at RPI Designs
Status
Not open for further replies.
RPI Designs
Salem, Ohio
www.rpidesigns.com
2015 Mustang GT - Test Mule
2015 2016 2017 Ford Mustang ROUSH 20" x 9.5" Quicksilver Cast Aluminum Wheel $474.99
A new set of wheels is one of the most rewarding upgrades you can make to your Mustang. Improve handling, make room for bigger brakes, and turn heads with ROUSH 2015-2017 Quicksilver Finish Cast Aluminum Wheels. These rims have a unique split 5 spoke design that compliments the 2015-2017 Mustang’s body lines perfectly, while the 20 x 9.5 inch size fills the wheel wells better than stock. These are the same wheel type used in all 2015-2017 ROUSH Mustangs including the RS3. The eye catching Quicksilver finish is protected by a clear coat that still gives the effect of clean bare metal wheels.
Roush Performance has long been known as the leading tuning for the Ford Mustang. Anytime you purchase a Roush product you can rest assured that product is built to the highest possible specifications for your 2015-2017 Ford Mustang.
http://www.rpidesigns.com/shop/item.aspx/2015-2016-ford-mustang-roush-20-x-95-quicksilver-cast-aluminum-wheel/
2015 2016 2017 Ford Mustang ROUSH 20" x 9.5" Polished Cast Aluminum Wheel $499.99
A new set of wheels is one of the most rewarding upgrades you can make to your Mustang. Improve handling, make room for bigger brakes, and turn heads with ROUSH 2015-2017 Polished Cast Aluminum Wheels. These rims have a unique split 5 spoke design that compliments the 2015 Mustang’s body lines perfectly, while the 20 x 9.5 inch size fills the wheel wells better than stock. These are the same wheel type used in all 2015-2017 ROUSH Mustangs including the RS3. The eye catching polished aluminum finish is protected by a clear coat that still gives the effect of clean bare metal wheels.
http://www.rpidesigns.com/shop/item.aspx/2015-2016-ford-mustang-roush-20-x-95-polished-cast-aluminum-wheel/
RPI Designs
RPI Designs
Salem, Ohio
www.rpidesigns.com
Status
