Rolling Photos!
2015DIBGT
Benjamin
BrewCity
Benjamin
Who doesn't love rolling pictures?
Post up what you have!
Heres mine; Airlift 3p, Varrstoen ES2's
(and a couple stills aired out)
2015DIBGT
2015DIBGT
Benjamin
BrewCity
Benjamin
what psi and shock stiffness settings are you running on the 3p?
killer photos
Fronts: 26 clicks and 44psi (struts as short as they can be)
Rears: 24 clicks and 68psi (shocks as short as they can be)
I have Steeda rear shock mounts and they actually screw with ride height a fair amount. I lost about 3/8-1/2 of ride height after installing the mounts. The position they are mounted on the body lowers the physical shock position. So airing out, it "bottoms out" sooner. I compress the shock completely at about 35psi.
See photos for comparison... (rear fender difference)
Same ride height, psi, etc. Same alignment spec.
Subtle difference to the naked eye but it was literally a mount change change that they say is a direct factory replacement. (awesome part, didn't serve my purpose efficiently)
Before Steeda mounts:
After mounts:
