shadowx
what offset should i put if my wheel is 20x10? or i can put the same +22?20x9+22 | 20x11+48
depends on the company of wheels you are looking to get, some do offer 20x10 to work and some dont.what offset should i put if my wheel is 20x10? or i can put the same +22?
yes it's the same as the pic Rohana rfx5. my car is without ppdepends on the company of wheels you are looking to get, some do offer 20x10 to work and some dont.
Rohana has the 20x10+22 20x11+48, the +22 is a slight aggressive in the front on the 20x10.
I have gt19 without pp and im getting rohana rfx 20x10 f and 20x11 r. but dont know which offsets to get.depends on the company of wheels you are looking to get, some do offer 20x10 to work and some dont.
Here are the fitments:I have gt19 without pp and im getting rohana rfx 20x10 f and 20x11 r. but dont know which offsets to get.
how does it look if i get +22 front and +28 rear? and is there any rubbing?
what about +40 f and +48 r ? which one is the best without problems?
so what are the best offsets I have to choose between ( from what to what ) for both front and rear for this car without adjustment? what did you mean by adjustment?Here are the fitments:
20x10+40 20x11+50 will need a 3/5mm spacer in the front to clear the grease cap and to use center caps
20x10+22 20x11+28 is to low of an offset that it will poke pass the fender both front and rear.
I have seen some use a 20x10+22 and 20x11+50 but the front needed some adjustment to work properly.
is it a problem if it will poke pass fenders? do I need adjustment? or it just looks aggressive?Here are the fitments:
20x10+40 20x11+50 would be the fitment with a 3/5mm spacer on the RFX11 with camber adjustment needed.so what are the best offsets I have to choose between ( from what to what ) for both front and rear for this car without adjustment? what did you mean by adjustment?
