Zelek
- Feb 11, 2016
- Round Rock / Hutto, TX
- Matt
- 2021 Mustang Mach 1
Brand new Rodeheaver's 2015-2017 Mustang GT S550 Return Fuel System. This system is good up to 900 rwhp and can be used with E85. The shop said this is not compatible with 2018+. Description from the shop below.
"This is our in house built and tested S550 Coyote Mustang Return style fuel system.
- It uses OEM GT350 dual fuel pumps, this means you have an OEM fuel pump that was designed to go 100,000+ miles!
- It also uses the factory FPCM and we add in a second FPCM so the pumps are not FULL BLAST all of the time like other
kits. This means the pumps will not wear out quickly like other kits do or overheat the fuel like other kits do!
- When you drive the car normally the pumps are running like the factory pump on a low speed setting controlled by the ECU then flip to high speed when you smash the gas.
- This kit will not cause any check engine lights and does not require special tune changes to function correctly.
- This kit comes with all quality components.
- It uses the 2016+ GT350 twin fuel pumps.
- This kit is plug and play other than cutting or de-pinning the factory fuel pump plug.
You get:
- GT350 twin pump assembly
- Aeromotive fuel pressure regulator
- Aeromotive fuel pressure gauge(liquid filled)
- AN line in black
- Ford OEM FPCM
- All required AN fittings in black
- Fuel rail adapter
- Plug and Play wiring harness"
The kit is good up to 900 RWHP. $1050 shipped or $1000 local pickup.
You get:
- AN line in black
- Ford OEM FPCM
- Fuel rail adapter
