Silver Dragon
- Jan 17, 2020
- North Wales
- Richard
- GT 5.0 mannual
As someone else recently asked the question was the RHD oil cooler solution designed to cope with a very hot day in Alice Springs.It begs the question do we really need an additional engine oil cooler in dear old Blighty??Looks very good job, well done.
My Question is: This Water/Oil Heat Exchanger, is it necessary to actually have it at all?
Why not plug the water connections at the exchanger, remove the water hose/pipework and plug these too. It's only purpose as far as I understand is currently is too get the Oil temp up using the Hot Water from the Radiator.
If the car is not modified or not being used for track days then perhaps we should just remove and bypass the troublesome oil cooler that can wreck the engine?
A blanking plate for the oil take off on the block and a “normal” hose and remove the other bits.
It needs a willing volunteer to do this and then report back on oil temps under a variety of driving situations.The engine may run hotter/colder but probably within the normal parameters. It seems very unlikely it will self destruct as it does if the cooler fails.
Is this a reasonable alternative to the fairly expensive (but not compared to a new engine) air /oil cooler?
