Burgo
I used the Motorcraft one as I can get them quite cheap. I'd stick to the shorter length one as there isn't much room in there and the longer one might make a difficult job even harder.What filter did you use?
I'm looking at using the Ford Racing High Performance filter instead of the stock Motorcraft one. The Ford Racing is mean to be taller (hence the better filtering).
Would this pose a problem when changing the filter do you think?
