Requesting image of lowering springs on stock tires and wheels
jbanh100
Houston
Jackie
2021 Tesla Model 3 Performance
Trying to get an idea what steeda ultralites 1 inch would look like on black accent wheels on stock tires (255/40/19). Thanks
Vstang2
Jason
2019 GT
Had these put on today , Steeda progressives with pro-active shocks ( Comfort package ). I have the wheels and tires you mentioned.
tj@steeda
Timothy
Thank you, Jason :)
ChrisS550NY
Staten Island NY
2016 Mustang GT 5.0
Not sure if you needed another photo but this is a 1" drop on SR progressive rate springs
20 inch factory wheels
Hope this helps
ChrisS550NY
Staten Island NY
2016 Mustang GT 5.0
1 inch spacers in the front and 1/2 inch in the rear
No problem with rubbing even if I had 1" in the rear I had no issues
Roadway 5.0
Strassejager
New York - USA
2016GT PP 6MT
Steeda Ultralites with a 1/4” spring spacer in the rear (raises rear 0.5”); stock PP wheels:
Edit: here’s another shot. Color grading is horrendous, but you can really see the wheel gap well:
Momogt26
VA
dwayne
2015 mustang gt
Which 1/2 inch spacers did you use on the rear and did you have to grind down the wheel studs
ChrisS550NY
Staten Island NY
2016 Mustang GT 5.0
I used the Ebiach 1/2 hub centric
But I did convert to longstuds in the rear
But at 1 time I had 1" bolt on spacers with there own studs on the rear no grinding at all
Please see attached
nomorework
Chelsea.Mass
Rick
Vstang 2 what do you think of the ride with that package installed?
ChrisS550NY
Staten Island NY
2016 Mustang GT 5.0
On my car I have
Koni yellows on all 4 corners ( adjustable).
Ebiach sway bars front and rear
SR springs ( 1 " drop ) no rake
On 20 " wheels
BMR subframe connectors
Bmr vertical links
Solid lower control arm bearings
Wheel spaces
Car handles great / little stiff as I have all settings on med / middle setting
The car is great at high speeds fully in control
( 120 140 MPH highway pulls )
The car is very rigid as it will Teeter on 2 wheels when pulling into a driveway on an angle
Are you the only thing I regret doing because i drive the car every day is I did BMR solid billet Carrier bearings I feel like I'm driving a go kart as you hear every driveline noise
Blacktop17
CT
2017 GT , 1986 GT
steeda springs, spacers- 25mm front 20mm rear
