mindys
- Jul 15, 2015
- Chicago Suburbs/South Nashville
- Mindaugas
- 2020 VW GTI SE
Hello all,
I got a question: I have a 2015 Mustang GT with the 9 speaker system. The head unit is replaced with a Sync 3 unit. I recently installed a sub and amp that I got for free from a buddy:
Amp: Kenwood KAC-7202 (2-channel, 150W @ 4 ohms/channel, 230W @ 2 ohms/channel, or 460W @ 4 ohms/bridged)
Sub: 12" Kicker 03CVR124 (4 ohm DVC, 400W) - Wired in series at 8 ohms
Box: Sealed, approx. volume 1.3 cu.ft. no leaks
Tapped into rear speakers using an LC2i (Bass threshold maximized), then to amp, then to sub. I oscoped the signal before the LC2i, after the LC2i and after the amp and absolutely no clipping at max volume (30). Have the gain/input sensitivity set so that sub is receiving 400W at max volume. Amp’s LPF is set to about 100 Hz right now. I believe it is a 24 dB/ octave filter.
While I hear the bass nicely, I don't really feel much of it, and also the box takes up space inefficiently in the trunk. I have been thinking of getting a Zenclosure rear fire box for two 10" subs that would be 4 ohm DVC and 300W RMS. I would wire each sub in parallel to have a 2 ohm impedance and then connect them to each channel on the amp that I have (so it would be 230W @ 2 ohms for each sub). My question is would these make me "feel" the bass more than the setup that I have now? I calculated that running the subs at a lower impedance would mean more current through the voice coils, so it should be more excursion on the cone plus more surface area to move the air. I just do not want to spend the money because I am not sure what this would mean in the real world. Anyone with some experience mind chiming in? Thank you!
