Replacement line for clutch master reservoir line leak!
Tomster
Beware of idiots
Tom
From memory I checked a Ford mechanic guys GT Mustang (6 speed) that is a couple years old and his was all the the way on. And it seemed if I remember right his reservoir was just a little different looking. But can't remember if taller/rounder. But yesterday I'd asked the dealership owners son if he checked his on his new 2017 California Special GT Mustang (6 speed) and he said his was all the way on. So assume the regular Mustangs its all the way on. So it might be they changed the the reservoir style on the Shelbys but didn't change the line to a longer one to compensate for a shorter distance.
Thee is no slack on mine and I think that is part of the problem
goodkid
Ohio
Kevin
2016 GT350; 2014 Polar Edition Wrangler; 2005 350Z
Very little slack here as well. I was able to push it just a little bit further on. No evidence of leaking here though - early 2016 build (chassis 703).
JN66
British Columbia
2017 GT350R, 1966 Couple (347 Stroker)
Mine was off 1/4-1/2 inch or so. Hard to push back on due to lack of slack.
No leaking. 2017 GT350 picked up last November.
montreal ponies
Montreal, Canada
‘17 Ruby red GT350
So it might be they changed the reservoir style on the Shelbys but didn't change the line to a longer one to compensate for a shorter distance.
Well that doesn't surprise me one bit. :tsk:
Sprintamx
Mid-Atlantic
2016 Shelby GT350
I can also report a loose line. Mine backed off enough to expose the barb closest to the bottle. There was the just the slightest amount of a weep; but, after track time, that's not surprising. I installed a small hose clamp, which will hopefully stop this issue.
Yes, the line should be about 1/2 inch longer.
Thanks for the heads-up OP!
rj45
2017 GT350 Magnetic Metallic
July '17 build here. Mine is secure and dry, but nearly a quarter inch from being fully seated. The line is also too short/tight.
kart125
Montreal, Qc
2017 GT350/2008 Saab TurboX SC
Took a look at mine. Was backed about 1/2 inch with BF dripping at slightest touch. I seated it and ziptied it.
cking
17GT350AG/BS-MGW/UPR/ABLIP
I wonder whats happen at the other end. Are we pulling it off the master, same connector both ends. I have spare line and master I'll post some pics maybe somebody will see a solution.
Colleton
Mustang Fan
NW Florida
2020 GT500, 2017 Edge Sport, 2013 Focus ST
A solution to what, exactly? Has one actually fallen off?
tdzee
Atlanta Motorsports Park
Tom
85 Corvette, 04 Corvette Z16, 08 350Z NISMO, 15 CTS-V Coupe, 17 GT350R
Just checked my 17R this weekend. 1100 mi. See photo. As reported by many others, it was not fully engaged. Line was very rigid when I checked it and it would not move. I was afraid to pull any harder that it might come off the other end. I will note the car was totally cold in the garage.
Then yesterday I had my first track day with this car at AMP. Checked it again when I arrived. The car had just been driven an hour. The line was noticeably more compliant/flexible when warm and with a push it went on readily with a click. My conclusion is the line is about an inch too short.
johnny1
Had new a 16 GT350 and 17 GT350
Ok so obviously on most if not all of the Shelby GT350's the line is to short and therefore not all the way on. I checked two GT Mustangs and there reservoir is made a bit different (6 speeds) and the line was all the way on. So since no one has reported a line coming off does that not mean Ford has no obligation to doing a recall (I see a safety issue here) or at least a tsb under warranty to to make a longer line and replace them all. Or is there some way this can be escalated to get Fords attention before something possibly bad could happen.
HizliBullet
GT350
Canada
Mustang
16 GT350, 17 Edge Sport
i need help finding this dongle
cking
Go to the thread I posted full of pics. master brake reservoir. Any other dongle ... your on your own
