- Nov 3, 2016
- Ontario, Canada
- 2015 Race Red Mustang GT
- Banned
- #91
Since all the speakers are at different distances from your ears the sound will hit them at different times making the music sound off. Driver sound stage will phase / adjust volume of all the speakers independantly so all the sounds from all the speakers hit your ears all the same time. That's a basic explanation of it.Exactly what does “Driver mode” do as far as the sound stage? To me it almost sounds like it knocks out the rears and moves everything to the front and to the “driver side”... almost unbalanced...
It makes the driver seat the center of the sound stage instead of some random center point in the car.
It just sounds unbalanced to you because your not used to having the drivers seat being the center of the sound stage. Your used to the sound stage being in the center.
Most home stereos will stage the sound. They will come with a little microphone that you place where you sit. The system then projects sounds which get picked up by the mic. This tells it how far each speaker is away from it by the time / volume the sound is when it hits the mic. Using this data the receiver sets the soundstage, adjusting the a phasing and volume levels from all the speakers. This sets that seat as the center of the sound stage and will sound the best compared to anywhere else in the room.
This is what driver soundstage is doing except you don't need to use the microphone step since Ford already knows where the driver seat is and has programmed the HU/amps accordingly.
