Recommend an installing dealer in the Central USA?
Discussion in 'Rockies / Midwest USA' started by Chipks, Feb 13, 2020.
  1. Chipks
    Chipks Well-Known Member
    First Name:
    Tom
    Vehicle(s):
    2018 Mustang GT - 10 speed - 3.55 rear - Roush P2 Blower
    Dec 29, 2019
    Kansas
    50
    42
    Occupation:
    Retired - Building Construction
    0   0   0
    I haven't made up my mind between a PD or Centri, but I'm looking for recommendations for an established and trusted installing dealer / tuner for a blower and oil pump gears / crank sprocket on a 2018 GT. I'm located in the middle of Kansas and closer is better, but I'm not against traveling 200-300 miles. Anybody got any suggestions?
  2. 96gt4.6
    96gt4.6 Well-Known Member
    Vehicle(s):
    2017 GT Premium/A6
    Feb 18, 2018
    Kansas
    253
    73
    0   0   0
    Where are you located in KS? Long Mac in Salina is a Roush Dealer and has built several RTR Mustangs via the kits using a base GT so they have done quite a few blower installs/setups on them. If looking for custom tuning you'll have to have that done after the fact elsewhere i'm sure, but something you could inquire about.
  3. 80FoxCoupe
    80FoxCoupe Well-Known Member
    Vehicle(s):
    16 GT, 80 Fox
    Mar 28, 2018
    Cincy, OH
    1,571
    931
    Rating:
    100%
    5   0   0
    BA Motorsports in Cincinnati get you done up.
  4. OP
    Chipks
    First Name:
    Tom
    Vehicle(s):
    Dec 29, 2019
    Kansas
    50
    42
    Occupation:
    0   0   0
    I'm assuming you work at Long Mac based on your sig line? Yes, I live in New Cambria and bought a white '18 GT 10spd with stripe from Darik in December. I've been leaning toward a whipple or vortech and haven't really considered Roush much because of heat soak issues I've read about, but now I see info on the phase II Roush blowers. You may be just the person I need to talk to....
    I talked to a local mechanic I'm familiar with and he recommended Long Mac for the install, but he said he thought they only did Roush and would not do the OPG / crank sprocket. Is that the case, or? Also, if you work at Long Mac, have they done some Phase II Roush blowers? Heard anything good or bad about them?
  5. 96gt4.6
    Vehicle(s):
    2017 GT Premium/A6
    Feb 18, 2018
    Kansas
    253
    73
    0   0   0
    I work at a Ford Dealer in Central KS, but not at Long Mac.
    From what I have kept up on research on my end, I concur that the updated Roush kit seems to address the heat soak issues. That was my reasoning for going Whipple back when I did my kit, which was before the heat soak issue was corrected. Otherwise, I would have preferred the Roush kit simply because they work closely with the OEM, however so does Whipple.
    Not confirmed, but given Long Mac advertised not long ago they were building a couple RTR's by showing the parts boxes/ect, one would assume they did the install, including the Roush blower.
    I would give them a call and see what they say. They seem to advertise and move a lot of Roush product, i'm sure they can answer your questions on the OPG/CS as well.
  6. OP
    Chipks
    First Name:
    Tom
    Vehicle(s):
    Dec 29, 2019
    Kansas
    50
    42
    Occupation:
    0   0   0
    Thanks for the info! Damn! Now I'm thinking seriously about the Roush.....I just called them and they quoted me $10.5K installed, plus tax. However, they don't do the OPG / CS as they claim it's covered under the warrantee. Not like I'm going to be drag racing it. I'm a 55 yo Grandpa whose last hotrod was a 69 Mach 1 w/ about 450 hp and a 4 speed. I'm sure this would give me plenty of zip to play with now and then. lol.
  7. whatsup62
    whatsup62 Well-Known Member
    Vehicle(s):
    2015 Mustang GT PP
    Sep 16, 2015
    Jupiter
    2,010
    484
    Rating:
    100%
    7   0   0
    96gt4.6 likes this.
  8. OP
    Chipks
    First Name:
    Tom
    Vehicle(s):
    Dec 29, 2019
    Kansas
    50
    42
    Occupation:
    0   0   0
    Thanks for the recommendation! I already jumped on a Roush phase 2 blower to be installed by my local Ford / Roush dealer. I'll keep your this for possible future use.
    whatsup62 likes this.
Loading...
Share This Page
