Rear tire wobble at wot?
NGOT8R
Adrian
2019 Bullitt
Ok so I’m gonna go with the irs bushing supports and the alignment kit for now and see how that does. Will the car need an alignment after these parts are installed?
That’s a good start, but I really think you should install differential bushings too. You can use the red ones for less NVH (even though mine is rated at a 2-3 out of 10 and I’m using the black ones). I think that will be enough to get rid of the hop. Do a search for torn differential bushings. That occurs from excessive wheel hop over time. If they tear on you, it’s going to be a lot more work involved to correct the issue, as the whole bushing will need to be removed and replaced. You shouldn’t need an alignment, but it’s not a bad idea to get one. I did.
