smoke_wagon_6g
I have an 18 manual with the 3.55 LSD.
The instrumented tests of the 2018 Mustangs you find on the web and in the magazines are done with the PP Mustangs that have 3.73 Torsen rears. I want shorter gears like the PP, but even shorter.
I'm actually looking at installing the 4.09s since they ought to be a blast around town. I live in second and third gear most of the time anyway.
Does anybody have back to back 0-60 and quarter mile times available where the only change is rear gear?
I'm curious if my 3.55 is running the same times as a 3.73 PP with the same HP, and if true, if the 4.09s would pick up any time over the 3.73s.
This is again with an MT-82. I know the auto has shifting programming that would be confused. And I'm aware that the speedometer and MPG are affected. The way I see it a tune wouldn't even be required unless the speedometer error is annoying.
This is the ring and pinion I saw available:
https://performanceparts.ford.com/part/M-4209-88409A
