djcodeman
- Oct 10, 2021
- Austin, Tx
- 2015 GT roush SC
So far so good...Did the washer and the improved axle nut fix your issue? I am chasing a similar clunk.
Which part - the thrust washer?What all would I need to get out to replace that part? From what it looks I would be good getting the wheel bearing out (as shown in this video) or is there more to it? Would I need to get something adjusted after that?
You have to take the half shaft out of the hub. The washer goes on the half shaft then you put it back in the hub and tighten down the axle nut to 150 ft lbs + 1/8 turn with red loctite.Wait, are we talking about the thrust washer here or the axle nut? I was talking about the washer.
look at my pic july 26th.... there are multiple versions of the washer, but the principle is the same.I thought the washer was under the nut and outside of the hub. If not, then My Bad! Or maybe there are two washers - one inside and one outside?
That's what I was looking for, thank you. I am not quite sure if I feel confident to do that on my own. If I decided to do that, is it just losen and tighten nuts and screws or would something need to be aligned afterwards? If the latter I am definitely not going to do that myself.You have to take the half shaft out of the hub. The washer goes on the half shaft then you put it back in the hub and tighten down the axle nut to 150 ft lbs + 1/8 turn with red loctite.
It's not that bad. Not as bad as RLCA bushing.
The trickiest part is switching among various sockets and extensions because the four bolts on the hub backside don't have the best direct access.
It won't affect alignment.
