TireSlayer
I have a 2019 Mustang Gt. I am getting a rattle over bumps and pulling out of my driveway only. Here is my list of parts installed. I thought the issue was front at first. Then i laid down my back seat and definitely heard it from the rear.
20 inch MRR M600 10 inch front and 11 inch rear. 275/35 - 305/35 <-- I know this has nothing to do with it. Rattle was happening on stock wheels
I torqued every single bolt on the front and rear suspension to factory specs. The one thing I just thought of, I did not check if both sway bar endlinks are adjusted to same height. Im sure they are though. I adjusted all 4 shocks to the same rebound. Rear springs seem to be centered with weight on vehicle.
I am kind of out of ideas...Any thoughts?
- Steeda Mustang IRS Subframe Bushing Support System
- Steeda Mustang IRS Subframe Alignment Kit
- Steeda Mustang Billet Aluminum Vertical Links
- Steeda Mustang IRS Subframe Support Braces
- Steeda Mustang Adjustable Rear Toe Links
- Steeda rear sway bar with billet bushings
- Steeda rear sway bar endlinks
- Steeds front coilovers with camber plates.
- Steeda front sway bar with billet bushing.
- Steeda front sway bar adjustable end links.
