Randy turned a 1:36.83 in the 2019 GT350 during MT's BDC.
Discussion in 'Shelby GT350 Mustang' started by FastCarFanBoy, Nov 11, 2019.
  1. FastCarFanBoy
    FastCarFanBoy Well-Known Member
    Vehicle(s):
    2013 GB GT
    Feb 21, 2016
    717
    489
    0   0   0
    Didn't see this mentioned anywhere. He turned a 1:36.11 in the R during 2016's BDC for reference.
  2. NorthernBeast
    NorthernBeast Well-Known Member
    Vehicle(s):
    Black '17 GT350
    Jan 21, 2018
    Canada
    121
    Garage Profiles:
    The 2019 GT350 now comes with the Sport Cup 2's so what you're seeing is the advantage the tires gave the R cars. The other upgrades on the R (aero, etc) make up the remaining gap in lap time.
  3. Droopy1592
    Droopy1592 Well-Known Member
    First Name:
    Damien
    Vehicle(s):
    2017 GT350
    Apr 11, 2019
    Atlanta
    391
    173
    0   0   0
    I always thought there would be less than a second difference between the R and Non-R with the same tires.
  4. newmoon
    newmoon Well-Known Member
    Vehicle(s):
    04 Cobra, 10 SS, 12 392, 12 5.0
    Mar 28, 2014
    NC
    254
    176
    0   0   0
    #4 newmoon, Nov 13, 2019
    The difference now is likely the advantage of the CF wheels, with the improvements to the 19 aero and cup2 tires I would guess it is now very close to the R
  5. Demonic
    Demonic Well-Known Member
    First Name:
    Vehicle(s):
    GT350R
    Feb 21, 2017
    Boston
    948
    883
    0   0   0
    The Cup 2's on the R are a different tire compound than the Cup 2's now on the GT350, per Billy Johnson. The name was used more for marketing.
    Wildcardfox and raiderjatt02 like this.
  6. Droopy1592
    First Name:
    Damien
    Vehicle(s):
    2017 GT350
    Apr 11, 2019
    Atlanta
    391
    173
    0   0   0
    I got chastised here for asking for the tread rating between the two same-named tires for comparison purposes. I think there’s a letter or symbol difference between the two and I think expected mileage is closer to 10k (vs 2k for the R version). It’s still impressive that even with less sticky tires the non-R is that close. I’m guessing the R version may have a slightly improved time as well.
    Hack likes this.
  7. mkonrad
    mkonrad Well-Known Member
    First Name:
    Vehicle(s):
    2016 GT350 Oxford White
    Sep 8, 2016
    Austin, TX
    243
    170
    Garage Profiles:
    Rating:
    100%
    1   0   0
    The tread rating is a government thing. It's the way you can see a 200 tread-wear rating on an RE71R, yet they are softer than another 200 tread-wear - which is used for classing purposes in autocross, so there's a reason to "cheat" and stay at a certain rating of 200. The tread-wear is measured under controlled government testing, and the test cycle doesn't include timed laps at Laguna Seca by a prepped race driver. For the purposes of government ratings, the tread-wear will will probably remain at 180 (PSC2) even with a different compound as the load rating changes.
    Billy also seemed to hint that the PSC2 on the GT350R is about the softest available. Porsche PSC2 has a higher load rating, and the GT350 PSC2 has a 35 aspect ratio.
    Randy runs Laguna Seca this all the time, but across a different day ... and in 2016, hard to compare to now. There's no shortage of people here trying to figure out which of the tires, wheels, weight, aero actually makes the difference, but they'd have to be tested in the same conditions to satisfy the skeptical crew here and put this to rest.
  8. Hack
    Hack Well-Known Member
    Vehicle(s):
    Mustang, Fiesta
    Nov 26, 2014
    Minneapolis
    9,921
    5,006
    0   0   0
    The GT350 also has different programming for the anti lock brakes, different spring rates, and I think they changed the advancetrac setup as well.
    I agree tires are probably a big improvement to times, but I would be willing to bet these other changes improve lap times as well.
    svttim and NorthernBeast like this.
  9. Austinj427
    Austinj427 Well-Known Member
    Vehicle(s):
    2017 GT350
    Aug 31, 2017
    CO
    807
    444
    Garage Profiles:
    This was also on a completely different day.
    There are a lot of variables to take into account.
    svttim likes this.
Loading...
Share This Page
