Raceseng Mustang Tug Tow Hook (Front) - Red
[email protected]
Dunn, NC
2018 Saleen Yellow Label
We are proud to offer the Raceseng Tow Hooks for your s550 Mustang. These start at $335.00. Let us know how we can help!
SPECS
• USA milled high grade alloy steel shaft and aluminum ring
• CNC machined for precise fitment and function
• Superior corrosion resistant multi-stage finish
• Manufactured by Raceseng in the United States
FEATURES
• Available in black, graphite and red powder coated finishes
• Simple ring locking bolt keeps the ring in a vertical or horizontal position
• Capture footage with an optional bolt on GoPro Mount (Tug View)
• Interchangeable with all other Tug System components
• Meticulous Raceseng design language
• Capable of 8,000lb straight pull
RING POSITION
The Tug features a simple cross bolt design that can be tightened to lock the Tug ring in your desired position. The bolt is also removable allowing you to easily replace your Tug Ring.
TUG VIEW \ GOPRO MOUNT
The Tug View is a rigid, bolt-on GoPro mount, the Tug View slips over the front of our Tug and is secured with a bolt from the bottom.
Can be purchased here:
https://www.hypermotive.com/racesen...6-tug-tow-hook-front-red-06301r-1526101-0632/ - RED
https://www.hypermotive.com/racesen...50r-v6-tugless-view-front-06303-1526101-0632/ - GoPro
https://www.hypermotive.com/racesen...tug-tow-hook-front-black-06301b-1526101-0632/ - BLACK
https://www.hypermotive.com/racesen...-tug-tow-hook-front-gray-06301g-1526101-0632/ - GRAY
Advertisement
173 - AWE - 1
Advertisement
