question re changing color of calipers
Discussion in 'Suspension, Brakes & Chassis' started by rocky5517, Jun 18, 2019.
  1. rocky5517
    rocky5517 Well-Known Member
    First Name:
    sam
    Vehicle(s):
    ford explorer 67 riviera
    Aug 5, 2018
    north jersey
    183
    74
    0   0   0
    I have a '19 GT Premium. All Magnetic, no black roof. Changed the badge from red to black, as well as the pony at the grill. Stock wheels ( black) which I like. To liven it up I was thinking of changing the calipers to red.
    As far as I can see there are 3 ways;
    - painting the existing
    - adding covers over the existing
    - buying red ones and storing the originals.
    With only 3000 miles it seems a waste of $ to shelve the originals. I've heard different opinions re the covers and heat build up. I'm not a racer but I'd hate to have excess heat warp anything. I could see myself painting the originals, but what do you think of buying the covers ( or maybe just a front and rear), putting them on temporarily, and see if I like the look?
    If I like the look, which way to go? Are the covers expensive? Does Ford make them?
  2. Jimmy
    Jimmy Well-Known Member
    First Name:
    Jimmy
    Vehicle(s):
    2019 Mustang GT PP 6MT
    Apr 14, 2019
    Ontario
    95
    The covers seem to be quite expensive, $250 for a set of 4.
    https://www.americanmuscle.com/2015-mustang-caliper-covers.html
    It's only $10 for a can of caliper spray paint.
    I painted the calipers on my acura a few years ago, when I sold that car a year later they were still looking good. It's not a difficult job, you just gotta use a lot of tape and newspaper to cover up everything else.
  3. Ghost50
    Ghost50 Well-Known Member
    Vehicle(s):
    2019 Magnetic Metallic GT PP1
    Sep 17, 2018
    Houston by way of Philadelphia
    784
    454
    0   0   0
    I used the G2 Caliper paint. I went with blue as my secondary color. The G2 Kit came out smurf like blue so I used some Duplicolor Blue Metallic spray paint over that and I like it. Not as fresh as if I would have powder coated them but still nice.
    It took me about ten hours worth of work over two days and most of that was masking and covering the car.
    I also changed the point in the 5.0 emblems to blue and bought metallic Brembo stickers from Anchor Room. I will post a pic later from my phone.
  4. OP
    rocky5517
    First Name:
    sam
    Vehicle(s):
    Aug 5, 2018
    north jersey
    183
    74
    0   0   0
    Cool/ look forward to seeing the pix.
  5. Ghost50
    Vehicle(s):
    Sep 17, 2018
    784
    454
    0   0   0
    One with just the G2 and then obviously the final look after Duplicolor.
    I think the G2 gets that smurf color blue because of the black paint originally on the calipers. If I did it again Iā€™d try laying down a white primer first before putting the G2 Blue on. 5E9920D5-523D-4F4D-9EF0-7E7678AAAA62.jpeg E9C150F6-4031-4ABE-90FE-EFA632AABF5C.jpeg F0CC6EB9-0941-4707-820C-10467CE2FE1A.jpeg
    Cardude99 likes this.
  6. OP
    rocky5517
    First Name:
    sam
    Vehicle(s):
    Aug 5, 2018
    north jersey
    183
    74
    0   0   0
    Looks pretty good! Nice job masking.
    Ghost50 likes this.
  7. XCRN
    XCRN Well-Known Member
    Vehicle(s):
    2016 Mustang
    May 23, 2018
    Springfield OH
    73
    49
    0   0   0
    You can easily paint them on the car, and there is nothing wrong with that if you mask it right. The big thing is preping the surface. Given how low miles your calipers are there should be little to clean, but regardless CLEAN them good or it will not last. It is much harder to do this while on the car.
    Me personally, I got a second set of calipers base GT 4 piston calipers for $50 to dissassemble, sandblast and powder-coat, not sure what color yet but I am thinking just red. I do my own powder-coating so it is a bit easier for me to go this route. I did gloss black calipers for a LS swap BMW project of mine. 6A949D7A-DB04-42F0-A1D6-992C4E53AB35.jpeg
  8. OP
    rocky5517
    First Name:
    sam
    Vehicle(s):
    Aug 5, 2018
    north jersey
    183
    74
    0   0   0
    Geez they look great/ I never thought of the powder coating.
  9. wilsons550
    wilsons550 Member
    First Name:
    Wilson
    Vehicle(s):
    2019 Mustang GT
    Dec 17, 2018
    Canada
    Painted with G2 calipers paint.
    AD1067DC-6341-4AE5-80CB-9FE479517561.jpeg 8F8DC7D1-7286-4C5A-8492-BEA2B2AD24EB.jpeg F028AD3F-A18E-42B3-B859-A05C7EAC8E91.jpeg
    rocky5517 and samd1351 like this.
  10. Mdell2
    Mdell2 Member
    First Name:
    Mario
    Vehicle(s):
    2019 GT
    May 28, 2019
    Miami
    I had mine professionally painted for $395.00 and they look amazing 20190615_152656.jpg
  11. DekiDoo
    DekiDoo Well-Known Member
    Vehicle(s):
    2018 GT PP1
    Jan 21, 2019
    Glendale, AZ
    584
    524
    0   0   0
    JCFoster, rocky5517 and samd1351 like this.
  12. 2015Etrac
    2015Etrac Well-Known Member
    Vehicle(s):
    Black 2016 Mustang GT Premium 401a
    Aug 2, 2016
    PA
    1,481
    317
    0   0   0
    I really wanted the Brembo brakes so I replaced my 4 piston GT brakes, which I was originally planning to paint, with a set of the red 6 piston Bullitt Brembos, but I did paint the rear calipers with the G2 kit and they turned out great.
  13. barilda
    barilda Member
    First Name:
    Daniel
    Vehicle(s):
    2019 Mustang GT, magnetic grey, 301A, 6M, active exhaust
    Mar 27, 2019
    Ontario, Canada
    Painted mine with VHT caliper paint... turned out great. A lot of work, but it's cheap.
    Used a dremel to grind down all the casting marks on the rear calipers to make them look cleaner.
    Also wrapped the face of my wheel with black vinyl, blacked out my badges, and tinted the reflector on the headlights.
    Happy with the results! 20190527_192615.jpg 20190527_221937.jpg 20190615_144132.jpg 20190625_123501.jpg
  14. OP
    rocky5517
    First Name:
    sam
    Vehicle(s):
    Aug 5, 2018
    north jersey
    183
    74
    0   0   0
    I never would have thought of gold but they look good!
  15. OP
    rocky5517
    First Name:
    sam
    Vehicle(s):
    Aug 5, 2018
    north jersey
    183
    74
    0   0   0
    Years ago Cadillac, with their 72-76 Eldorados, color coded the hubcaps to match the color of the car. What would happen if Ford ( or anyone else) color coded the caliper covers to the color of each particular car? Beside the extra cost,?
Loading...
Share This Page
