Question for guys who actually have the the Roush Kit
JIMJH154
UPSTATE NY
JIM
2018 Roush JH
Thanks for the pictures Doug. Today my blower is off to Jokerz . Ordered my spacers and thermal blanket from FI Interchiller Yesterday . My IC interchiller just arrived yesterday .I do have a Vmp under hood Ice tank going to do what Shift rom rhas done .I think someone suggested a bigger Cwa pump which size would work Thanks . Also I didnt want to go with the 103 throttle body but from what engineer Mike said I will go that route .I will also be ordering the cobra R style hood from cervini I think its a 3 inch cowl hopefully everything fits under it . Were can i get a big enough inlet tube to fit the 103mm from solar also do i need a spacer and what would you recomend size .Your suggestions are greatly appreciated.
DougS550
Fishers, Indiana
Doug
I upgraded to a CWA400 and from what I have read is the highest flow pump on the market. As far as inlet tube, I would ask them who makes one. If the whipple has one which would fit?. You know by adding the Interchiller, thermal spacers and heat blanket I feel will aid so much in keeping the blower cool and keep your AIT2 low which can only help. A three inch cowl hood will definately give your the clearance needed and allow air to be removed from under your hood.
DougS550
Fishers, Indiana
Doug
Sorry CWA pump
I got mine from FI Interchiller with their special made -12an male flare inlet and outlet fittings. It does make them more expensive but I wanted AN male inlet-outlets and not the 3/4" heater hose ends.
DougS550
Fishers, Indiana
Doug
I got mine from FI Interchiller with their special made -12an male flare inlet and outlet fittings. It does make them more expensive but I wanted AN male inlet-outlets and not the 3/4" heater hose ends. I also got it with the wired connector. So I bought 40 amp relays and 8 and 10AWG to wire my CW400, the FI Condencer with fan, Cabin Solenoid etc in. I also will install a delay relay on the CW400 so it stays running 2 minutes after shutdown which also has a low voltage cutout circuit to protect the battery in case it is low.
DougS550
Fishers, Indiana
Doug
I also bought my FI intetchiller kit, Whipple Stage 2 kit, QA1 CF DS, GForce Axles, Anderson composite parts, etc from Beefcake. I have found when ordering big items or small, if you have an issue with that kit or part, Beefcake can get answers or resolve any issues you might have much quicker.
The Watchman
North of Indy
2022 Mustang GT
Yes, I spoke to several different parts shops when doing my research. After meeting Terry, @beefcake I don't think I will ever order anything anywhere else...lol...tremendous customer service and prices.
beefcake
Bethel
2018 Ford Mustang
@JIMJH154 I also got mine through FI Interchiller via beefcake. Hit up @beefcake and he’ll get an order going for you.
appreciate that guys
DougS550
Fishers, Indiana
Doug
In all reality, I always try to give my business to small owner run company's who are working hard to help their family. Not the Corporations who couldn't care less about the people they sell their products to.
hlfbkd420
SW 'Merica
Bilbo Hicks
2015 KIA Sorento SXL
Oh boy... the mystery has been solved.
I added the exhaust valves by way of a dual polarity switch and some power to the actuators on the factory active exhaust (mine didn't come with it).
For testing since putting the supercharger on I've had the valves closed so I could hear if the engine was about to grenade itself.
Today I went out to see if I could figure it out, opened the valves... no issue! Boost is down to 12psi, revs cleanly all the way. I caused my own issue there.
I'm so happy, that wasn't a fun time figuring it out.
I do not recommend using the AE or having those valves closed at all. Even if you don't have cat's I don't think it's good for the car. Mine had 0 issues for the longest time but when I had to replace the engine, the AE caused all sorts of issues. There were other things going on but when the car was in quiet mode in the mornings and I cold started it, it ran like shit. Promptly melted the cats... It was a PITA
DougS550
Fishers, Indiana
Doug
I do the quiet start and it purrs like a kitten with the Wengerd Tune. I drive in Sport mode when I leave the house so not really any restrictions as far as my OEM exhaust. I might put a high quality exhaust system from Cats back but it will have to have the AE. Dont know which exhaust are rated the highest as far as performance and still not stupid load.
ZLwhat
2015 Mustang GT
Without reading through all 884 pages lol, although I probably will, what are your thoughts on a 2015 GT Premium with 55k miles with the below modifications?
ROUSH Phase 2 Supercharger Kit Includes:
ROUSH TVS R2300 Supercharger
ROUSH Low-Restriction Air Filter Induction System
ROUSH Large Aluminum Intercooler
ROUSH High-Flow Fuel Injectors
ROUSH 60mm Dual-Bore Throttle Body
ROUSH Custom Designed Heavy-Duty FEAD System
Higher Boost 80mm Pulley
High Performance Spark Plugs
BBK Performance Exhaust
American Racing (Style: AR920) Wheels
Custom Suede Flat-Bottom Steering Wheel
Carbon Fiber Shift Knob w/ Carbon Fiber Boot Trim
